Old 04-11-2011, 07:20 AM   #31
infernosg
IT'S ALIVE!
infernosg's Avatar
Originally Posted by josh18_2k View Post
you can always get a center link to take out some more camber. afaik, the only thing stopping you from using the upper holes is some steel that could be cut out. doesnt really look structural...
I have the AWR unit but it's not installed. I bought it before I did the rear end swap so I didn't know I was going to go with delrin subframe mounts at the time. I didn't think the adjustable link would work if you had delrin subframe mounts. Kind of like how the individual camber links won't work if you have delrin bushings in the control arms.
