#16 |
Did you replace the "bushing" that are in the "ears" of the rear diff case?
The stock ones are "hollow" with just a few "spokes" (I think 4 per side?) that allows the rear diff to move a lot. Did you replace this with one of the delrin units? -Ted |
#17 | |
IT'S ALIVE!
#18 |
all my fc's have had a decent amount of lash. it could just be the transmission. put it in gear (car off), and twist the driveshaft by hand to see
#19 | |
IT'S ALIVE!
What has me shitting bricks right now is the metallic "thunk" I'm getting during these on/off throttle inputs. Experience tells me the differential backlash is off, but I was ASSURED by a transmission/differential shop it was okay. My only other theory is that this noise is always around and that it isn't until after installing semi-solid mounts that it becomes audible. |
#20 |
Who's telling you that adjusting the TPS (throttle position sensor) helps with drivetrain lash? Bad advice - adjusting the TPS has absolutely nothing to do with drivetrain lash.
#21 | |
You can literally grab the rear diff and sometimes shake it with your hands and see the entire rear diff swaying under there. Imagine the amount of torque backlashing through the drivetrain? It's violent. I've never seen "solid" aftermarket mounts to replace those "Differential Casing Mount" (PURPLE). I've seen aluminum ones - TOO stiff. I've seen stiffer replacement for the "Differential Stop Washer" (RED) underneath - i.e. URAS - that don't really do squat either. If I could, I would try and play around with a SOLID polyurethane mount. If I ever get off my lazy ass, I might even try and play around with a brand new set of mounts and injecting some of that "gray weatherstripping RTV" into the voids - it's a trick some racer use for those bushings with voids in them. Those mounts are the cause of why the rear diff moves around so much. ![]() The other extreme problem (mentioned with the aluminum mounts) is that if those mounts are too stiff, you risk damaging the rear diff casing itself. Those mounts absorb a lot of the rear diff movement. Once you start to restict that movement, something else gets stressed. What happens is that the "ears" of the rear diff housing that those mounts are inserted in tend to crack off. Remember, the rear diff housing is made out of cast aluminum... To combat this problem, I've seen custom rear diff frame braces made to minimize the ears cracking. And now we're back to square 1... Also, if all of that isn't bad enough, the front diff mount is a stupid design. That mount resticts movement via a shear force of the mount - WTF??? This is where a pinion snubber comes in and does help...but it can only do so much. There is still a lot of movement up there. So what can you do? Most will tend to crank down (reinforce the front diff mount or solidly mount it) the front diff (pinion) to the rear subframe... Again, now you risk breaking the rear subframe itself - I've seen this happen also. And now we're, again, back to square 1... -Ted |
#22 |
IT'S ALIVE!
^^^ All good points. I've considered the RTV trick, but hesitated due to the concerns you've expressed. I've also heard of people inserting objects between the stop washers and mounts (like ground down hockey pucks) but that would lead to the same issue.
Everything that's "colored" in that picture has been replaced by the Mazda Competition mounts, which are supposedly 40% stiffer than stock. The only "solid" mounts I have are the subframe-to-body mounts, which are delrin. I checked for free-play in the drivetrain on Friday. Aside from discovering the left-rear wheel bearing is going, there was a little moving in the driveshaft at the u-joints, but it really is not that bad considering the car, and driveshaft, is 22 years-old. I'm now almost certain the ring and pinion backlash is off. There is a good amount of free-play in the rear wheels before I feel resistance. Time to go have a word with the shop that set the backlash... |
#23 | |
![]() That's what I have for my rear diff. I am also considering the MMR spherical bearings, as you cannot use individual camber adjusters with the delrin control arm bushings. My question is how can a spherical bearing give enough play to force camber adjustment while Delrin cannot? I would've thought that the bearing would be under more stress and would fail if adjusted too far under constant driving. |
#24 |
Poly/delrin is no good in the rear control arm because its motion is not uniaxial. poly/delrin doesnt 'twist,' so you're only supposed to use it in arms that move in one direction. The rear control arm twists due to the camber curve, and a spherical bearing allows it to articulate freely.
poly/delrin is fine in the front control arm since the front/rear mounts are on the same axis, so theres no twisting motion.
#25 | |
http://www.mmr-direct.com/catalog1/RX7FC/index.htm I hate it when vendors use "generic" pics for their pages. ![]() The pic you posted was for an "rx7diff" part. Yes, it does sound like their "Rear Differential Mounts" part is the part I'm talking about. Their plastic is still too hard for this application. It will tend to break the ears off the diff as I have mentioned earlier. As a side note, the engine and transmission mounts they offer are crap. I hate when vendors "get cheap" and offer these types of mounts that do not properly mimic (or do a better job than) stock mounts and bushings. Just because of this inferior design, I would never use their products. -Ted |
#26 | |
IT'S ALIVE!
Regarding "solid" mounts I'm a firm believer there needs to be play SOMEWHERE in the system. If everything is solid the vibrations get transferred right into the mounts and THEY WILL ultimately fail (low-cycle fatigue). As Ted said, you want some movement at the differential cover or you will break the mounting points. I only went with delrin subframe bushings was because the stock ones needed to be replaced and I could get both delrin bushings for less than the cost of one OEM bushing. |
#27 |
IT'S ALIVE!
Might as well keep this thread going...
Anyone else here have the AWR camber links? I currently have mine adjusted all the way "tight" to maintain -1 degree of camber in the rear, which in itself isn't a problem. The issue is with them adjusted all the way up the bolt is hitting the underside of the car. There are two "holes" on the lower part of the link (the part that interfaces with the control arm) arranged vertically. Right now the bolt is going through the lowest hole, but I was wondering if this could be changed to be the upper hole to gain a little more adjustment. Here's what I'm talking about: ![]() Notice how the bushings are in the lower hole on the link on the right? It looks like they could be inserted into the upper hole to get a little more positive camber back. Just curious if anyone has tried this or if this is even the purpose of the other set of holes. |
#28 |
there are two holes so that they dont have to make 2 different parts (left+right). you're stuck using the bottom hole. the link wont fit in the control arm the other way, unless you cut it up.
as for the bolt sticking through the floor, let it happen lol. its just sheet metal. mine punched holes in the floor years ago. if you actually care, you could just cut down the shank or buy a shorter one.
#29 |
IT'S ALIVE!
^^^ That's what I figured. I really don't care that the bolt is hitting the floor. What bothers me is that both of my rear coilovers are all the way up (~1/4" engagement remains) and to get -1 degree of camber in the rear the links are adjusted all the way together - there's no more room for adjustment.
When I get back from Mid-Ohio this weekend I'll get under there and take a look to see how much the control arm would have to be adjusted to use the upper holes. If it can be done with minimum cutting/impact to structural integrity of the arm I'm going to try it. This would give me so much more room for adjustment. |
#30 |
you can always get a center link to take out some more camber. afaik, the only thing stopping you from using the upper holes is some steel that could be cut out. doesnt really look structural...
