Old 03-11-2011, 01:22 PM   #1
jking01
jking01 is on a distinguished road
Question 06 Rx-8 start and idle problem
I recently bought a 2006 rx-8, now im having problems with starting it. It starts rough and idles high then dies out. If i give it gas it will stay running, can anyone let me know whats wrong with it. I would like to try and fix it myself before bringing it in. Ive heard it could be the apex seals are worn out aswell. Am i better off rebuilding the engine ?
Thanks
J.king
jking01 is offline   Reply With Quote
Old 03-11-2011, 01:47 PM   #2
jking01
could it be a fuel injection problem ?
Old 03-12-2011, 08:41 AM   #3
Coils and plugs are you enemy with a Renesis.
Get a compression test first and foremost. Do NOT spend money on coils and plugs unless you just want to spend the $$$.
Test compression, and test the coolant system. Trust me.
Next in line is the fuel pump. Mine died right before I sold my RX-8.
Old 03-13-2011, 02:52 PM   #4
diabolical1
I have radioactive semen
was it doing this when you bought it or is this a new development?
as said above, check your compression. however, another possibility is your catalyst (because of your coils). when my cat died a few years ago, my car exhibited the same type of behavior.
Old 03-13-2011, 03:19 PM   #5
Redshft
Redshft's Avatar
Redshft is on a distinguished road
Is the car throwing any codes at all? The RX8 is pretty wired up so a lot of problems will have a code in the computer. (eg. when my coils died, I was getting a Random Misfire code.)
2004 RX8 GT
1986 RX7 Track Car: 13B Bridge Port w/ Renesis Internals and Weber Carb
2003 MazdaSpeed Protege
1988 RX7 Convertible - new project
2004 Impreza and 2003 Legacy wagons for hauling groceries and The Dog
Redshft is offline   Reply With Quote
Old 03-15-2011, 10:32 AM   #6
Sephitrask
BOILED PEANUTS!!!
Sephitrask's Avatar
Sephitrask is on a distinguished road
When you say it starts rough, do you mean it is difficult, or that it shakes? Have you changed anything on the car since you bought it? is it stock? What is the mileage? Any idea on the maintenance history (engine previously replaced, cat, coils, oils and fluids, etc) IF it is a hard start, Before you get a compression test check and see if you have the revised starter, then get the test done. Also check for vacuum leaks, they can cause it to choke like that as well. If all those items check out, there is a good chance its your coils. FYI, Oreilys carries the updated coils for our car for $33, half the dealer price. And they are the same part from the dealer, same stamp on the side, from the same plant, just without the dealer markup. They also carry our spark plugs for $20.
www.rotarycarclub.com
"The way a Rotary engine makes power is ferocious, much like having a chainsaw under your right foot."
Sephitrask is offline   Reply With Quote
Old 11-14-2011, 02:20 AM   #7
stinksause
stinksause is on a distinguished road
yeah ... rx8 parts are expensive .... your engine may be blown ... do what the others said
stinksause is offline   Reply With Quote
Old 08-11-2012, 04:22 PM   #8
lee
lee is on a distinguished road
rx8 idle troubles
hi guys, just bought my rx8 2005 its a South African model, not sure the difference btween the left hand drive..anyways.. it takes a while to start & its idle is irregular, backfires like crazy!! what could it b b4 i take it 4 diagnostics?
lee is offline   Reply With Quote
Old 08-11-2012, 11:00 PM   #9
Sephitrask
BOILED PEANUTS!!!
Sephitrask's Avatar
It could be a bunch of stuff. See my post above. Did/does it have a check engine light? If so what is the code? mileage, maintenance, blahblahblah.... help us help you...
Old 01-11-2013, 12:38 AM   #10
GaryBuster
GaryBuster is on a distinguished road
IF the car has been "worked on", here's a story for you.... MY history is with RIP it in Ok City... they miswired the second stage fuel injectors with the first stage.... we went nuts for 4 months trying to find what was happening... until we traced the actual colored wires and found "Eureka"!! Had the same symptoms described here.
GaryBuster is offline   Reply With Quote
Old 01-11-2013, 02:09 PM   #11
jimstaz
jimstaz's Avatar
jimstaz is on a distinguished road
im having lot of problems with my car and reading my this post is giving me some trouble shooting ideas... wish me luck.. but if you look at my post about electric stuff to idle stuff see some of my details and how the problems went from this to that in order.. i need help and knowledge guys. thank you
jimstaz is offline   Reply With Quote
