Old 03-02-2011, 08:24 AM   #1
tweiss3
Mazda Lover
tweiss3's Avatar
Brakes, a good DD & Spirited Option
In the spirit of prepping for DGRR, and my typical daily driving, I am going to be swapping my single piston calipers for the set of 4 pistons i have sitting in the garage (bought for $15). I just need to get them painted (going red appoxy type paint). Now, I am thinking Hawk HPS pads, but where do you guys get your rotors? What's a decent cheap blank?
Old 03-02-2011, 08:27 AM   #2
tweiss3
Mazda Lover
tweiss3's Avatar
Also, do i need different caliper brackets or anything?
Old 03-02-2011, 08:38 AM   #3
My5ABaby
My5ABaby's Avatar
With my 4 piston fronts I've been using Hawk HPS pads and did not get any fade at Talladega or DGRR. I'm using generic Beck Arnley rotors and have had 0 complaints. Unless you want the bling I don't see the point in slotted, drilled, or dimpled rotors.
Community Service Manual
RotorWiki
Old 03-02-2011, 08:55 AM   #4
tweiss3
Mazda Lover
tweiss3's Avatar
Lol, psh, Slotted aren't needed as of yet.
These them http://www.oreillyauto.com/site/c/de...0062&ppt=C0009
Old 03-02-2011, 09:11 AM   #5
Pads are going to make the biggest difference. Go with what people have had good luck with. I've been running some KVR pads/rotors for a while now. They're getting swapped out this spring though for some MONSTER setups at all four corners. Something about going into a turn on the Dragon hot and getting serious brake fade will make one spend copious amounts of coin on a set of brakes
Old 03-02-2011, 12:37 PM   #6
firzen
For the road, go to the Tire Rack and get Brembo OEM replacements with Hawk HPS pads. If you don't mind the copious dust and noise in favor of braking power, get Hawk HP+.
Old 03-02-2011, 12:40 PM   #7
tweiss3
Mazda Lover
tweiss3's Avatar
You recomend the Brembo blanks?
As for the pad, the reason i chose the HPS is due to the fact its a DD and needs to be able to stop when its -10* here
Old 03-02-2011, 03:40 PM   #8
My5ABaby
My5ABaby's Avatar
They're probably all made by the same company anyways. Just get what you can find cheapest.
HPS would be a better chioce.
RotorWiki
Old 03-02-2011, 03:45 PM   #9
tweiss3
Mazda Lover
tweiss3's Avatar
That's what I figured. Now to drop more money this coming paycheck. Horay!!!
Old 03-02-2011, 07:52 PM   #10
JL1RX7
I use hps on my very with cquence dimpled and slotted rotors. Never had an issue in three years I have had them on. I think you can get them for about 150 for all four right now. I know he used to do group buys on the other boards.
Old 03-02-2011, 08:20 PM   #11
firzen
HP+ has been fine for everything I've tossed at it- DD, autocross, ice racing. They're just noisy and dusty.
Nothing wrong with the Brembo blanks...
Old 03-03-2011, 08:42 AM   #12
My5ABaby
My5ABaby's Avatar
I agree there's nothing wrong with Brembo blanks, you're probably just paying too much for the name.
I'm sure HP+ has been fine for those things, but why go with the noisy and dusty pad when the HPS will be far more than adequate. As I said, I had 0 issues with them on a track so they get my vote as way more than is needed.
RotorWiki
