Old 12-30-2010, 05:46 PM   #31
Judge Ito
Porting Master
Judge Ito is on a distinguished road
Originally Posted by RotaryXperiment View Post
will it matter if u are using new or used apex seals to have a difference with these redone housings?
I have personally used them with new apex seals on every build. sometimes used apex seals have a step on them. so If you do use, used apex seals that spec. out good enough for a rebuild. a longer break in process will have to take place.
Judge Ito is offline   Reply With Quote
Old 01-01-2011, 10:17 AM   #32
RotaryXperiment
RotaryXperiment is on a distinguished road
motor has about 10k miles on atkins seals. the front iron cracked on dowel land so i gotta tear it down and replace the plate. btw ITO its alex.
motor still sounds like it has compression
RotaryXperiment is offline   Reply With Quote
Old 01-01-2011, 11:52 AM   #33
To_Slow
They look good, How many thou.001 max do you grind down on the housing?
What type of CNC/grinder do you guys you use to keep it very consistent...?
Thanks
My link
Old 01-01-2011, 02:19 PM   #34
Judge Ito
Porting Master
u cracked a plate? you have other issues to worry about Alex..
Old 01-01-2011, 02:21 PM   #35
Judge Ito
Porting Master
Thanks
I have no info. on this. Just from personal experience they found a way to provide a better rotor housing to work with..
Old 01-01-2011, 04:18 PM   #36
RotaryXperiment
ya the front plate cracked sux. but wat can i do
Old 01-01-2011, 11:18 PM   #37
JustJeff
JustJeff's Avatar
Do you know what caused the plate to crack? Would suck to put the engine back together without correcting the cause of the problem...and then crack another one.
Old 01-02-2011, 10:14 AM   #38
RotaryXperiment
over boost from hose popping off for wastegate.
these housings looked grooved up, might have to send them out. they arent deep enough to get caught by your fingernails but u can feel it when passing fingers over the surface.
Old 01-03-2011, 09:34 AM   #39
Judge Ito
Porting Master
send them out. and use new apex seals.
Old 01-03-2011, 09:48 AM   #40
RotaryXperiment
which seals should i go with ito? and should i replace oil control o rings as well?
here is the housing
File Type: jpg 131718_1712938461937_1192420271_1826140_447512_o.jpg (94.2 KB, 101 views)
Old 01-03-2011, 04:46 PM   #41
Judge Ito
Porting Master
here is the housing
Alex, there is a variety of apex seals on the market. do your homework and then purchase some. No more tips for free..
Old 01-03-2011, 04:49 PM   #42
Judge Ito
Porting Master
and yes that housing will end up flawless with Goopy's refinishing job.
Old 01-12-2011, 12:22 PM   #43
I really like the look of this, and I think that it's great to finally have an option to machine your housings, my only question is:
Why did this take 20 years, and how come no one figured it out before? Was it lack of precision technology, or what?
Old 01-12-2011, 01:07 PM   #44
Pete_89T2
Pete_89T2's Avatar
^I was thinking the same thing. There certainly was a need for this service!
Old 01-18-2011, 12:29 PM   #45
Gregory Casimir
hmm i might lookinto this more when i get home
Gregory Casimir is offline   Reply With Quote
