Old 12-21-2010, 12:11 AM   #16
Hitman Cody2130
FB junkie
Hitman Cody2130's Avatar
Hitman Cody2130 is on a distinguished road
I have looked at their site and cant seem to find the 5 lug conversion or a price on it. I talked to a local machine shop and was told that for between 3-4 hundred dollars I should be able to get all four corners redrilled.
Overkill is under-rated
Hitman Cody2130 is offline   Reply With Quote
Old 12-21-2010, 12:53 AM   #17
orion84gsl
Or you could spend half that on the front big brake kit by RE-Speed (the conversion kit) http://mrcmfg.com/catalog/product_in...products_id=37, add in some junkyard TurboII calipers, some cheap rotors and the stainless steel brake lines, some and decent pads and you've got better front brakes and the 5X114.3 bolt pattern that will give you the wheel options. Also in case you aren't aware, the front hubs are part of the brake rotor and the area that the lug screws into is thicker than the surrounding area of the hub. Unless your machinist is also a phenomenally skilled welder that can add material inside a ver narrow space, you probably won't have much peace of mind and will run the risk of serious damage, injury or death. RE-Speed also offers Moser axles that can be drilled any bolt pattern you want.
Old 12-21-2010, 02:17 AM   #18
RotorDad
Big Ugly
RotorDad's Avatar
+1 on the RE-Speed.
Boosted Big Body On 335's
PS3 ID: Rotordad
Old 12-21-2010, 02:54 AM   #19
TheDriver216
TheDriver216's Avatar
Old 12-21-2010, 08:03 AM   #20
Hitman Cody2130
FB junkie
but how much am I looking at for a full re-speed setup? Cuz based on what I need according to you guys I will be in to that setup $700+
Old 12-21-2010, 10:16 AM   #21
RX-7 Chris
RX-7 Chris's Avatar
It may be a little more money to begin with getting the Re-Speed setup but in the end you will have a better setup. Plus you won't have to worry about having the rotors drilled every time they need to be replaced.
The other way you could go would be with a GSL-SE suspension setup and get 4x114.
http://coloradomazdaclub.com
1984 RX-7 GSL-SE
1983 RX-7 GSL PARTING OUT + EXTRA
1964 Ford Galaxie 500XL 390 auto
1970 Ford F250 4x2 390 4bl C6
Old 12-21-2010, 08:26 PM   #22
mazdadude7
mazdadude7's Avatar
mazdadude7 is on a distinguished road
I have my full gsl-se swap that I have ready to bolt in basicly that I would go super cheap on and its got new everything. s.s. lines, hawk hp pads, new rotors, new bearings and its all been sandblasted, the front spindles were powder coated and the rear axel was primered and painted. the front calipers were epoxy coated and so were all the rotor hats, (didnt get to do the rear calipers ) and also have full set of volk wheels with new bfg tires that would complete your car 1000 bux for it all (i have more in the se swap than that)
call me (828) 421-8967
mazdadude7 is offline   Reply With Quote
Old 12-21-2010, 11:31 PM   #23
Hitman Cody2130
FB junkie
If I had a spare grand in cash I would buy that from ya but I just dont have the cash to spare right now.
Old 12-22-2010, 11:44 AM   #24
orion84gsl
If you don't have the money to do the job right then I suggest you hold off for a bit and save up. Better to spend a little more and have nothing to worry about.
