Old 12-04-2010, 06:26 AM   #1
dr50376272
dr50376272 is on a distinguished road
trouble removing old bolts please help
i dont know if this is the right place to ask, but i have 37 year mazda rx4 bolts on my air conditioning and oil cooler, and i cant remove them. what do you guys do to unscrew old bolts that are stubborn and recalcitrant? (my website is www.kagoshimaenglish.com/rx4.htm for pictures of my car).
i also made a video here to explain my difficulties:
http://www.youtube.com/watch?v=yAY1RKTDJ-o
thanks for your help good people !
best regards,
david
dr50376272 is offline   Reply With Quote
Old 12-04-2010, 07:25 AM   #2
N.RotaryTech
Home-brew Rotary
N.RotaryTech's Avatar
Try penetrating lubricants, "PB blaster", "WD-40", etc.
Also maybe heat the nut with a propane torch.
Looks like you'll need to redo the flare-nut piping too.
Good luck.
'87 RX7 GXL, Rest In Pieces.
'94 Ford Ranger, daily.
Old 12-04-2010, 07:32 AM   #3
Pete_89T2
Pete_89T2's Avatar
Didn't have a chance to look at your video, but try PB Blaster - it's a penetrating lube (like WD40) that works wonders on rusty old bolts. Give it a generous shot of the stuff, and let it soak in - if these bolts are really corroded, give it LOTS of time to soak in (many hours). When you do try to loosen it, make sure you use the right tool for the job - you don't want to slip or round off an already corroded bolt head.
Old 12-04-2010, 07:34 AM   #4
willnordacgreen1211
willnordacgreen1211 is on a distinguished road
here ya go!
willnordacgreen1211 is offline   Reply With Quote
Old 12-04-2010, 07:49 AM   #5
dr50376272
cant buy this stuff in japan. bolt isnt rusty, just wont budge. i can bench press 300lbs so even with my strength it wont budge !
Old 12-04-2010, 09:12 AM   #6
Pete_89T2
Pete_89T2's Avatar
Sounds like it's seized. Is it a dissimilar metal situation? As in a steel bolt in an aluminum threaded hole? Regardless, let it soak in the penetrating oil a good long time as suggested, try again. Use the longest handled breaker bar you can get in there. If it still won't budge, try an air impact wrench, preferably one that can deliver several hundred lb-ft of torque. If that fails, you might have to drill the stud out, retap the hole and get new bolts.
Old 12-04-2010, 01:40 PM   #7
N.RotaryTech
Home-brew Rotary
Those kind of stuck bolts really suck, cause its only held in there by the tubing.
All I can think of for now is, use said lubricants, also use a flare-nut wrench so it don't slip off, and maybe clamp some vice-grip pliers on the fitting to hold it in place while you wrench on the nut.
Old 12-05-2010, 04:24 AM   #8
JustJeff
JustJeff's Avatar
What I did with PB Blaster when I was pulling my motor was hit the problem bolts and let them soak for a couple days. I had time till the motor was coming out so I'd hit them once or twice a day for a couple days. When I finally got to pulling the motor the bolts came loose with no problems.
Not sure if that advice helps with seized bolts, but if you have time to wait then it certainly won't hurt anything.
