Old 11-22-2010, 03:55 PM   #1
sv51macross
sv51macross is on a distinguished road
Vac hose size?
So replacing the injectors/injector seals, I broke more than a couple vac lines and went to get some replacement. I took along one of the old pieces and 5mm has a slightly smaller ID than the old pieces. i come home and test fit the hose before I cut it, expecting it to be snug. It's loose! Do I need 4mm hose, or will it seal well enough...[?] Mazdatrix lists 3.5mm and 6mm hose, but the pieces I removed look bigger than 3.5mm, and are definitely smaller than 6mm.
1990 Mazda RX-7 NA; Lucy, after the main antagonist from Elfin Lied.
Eventual plans? Something cyberpunk and spicy.
sv51macross is offline   Reply With Quote
Old 11-22-2010, 04:05 PM   #2
LunchboxCritter
Simply Rotarded
LunchboxCritter's Avatar
LunchboxCritter is on a distinguished road
I'm running the mazdatrix silicon hose and they fit correctly. I would recommend getting them or some that are the same id. They do look alot smaller than the stretched out oem rubber hose, but I believe that the silicon has alot more stretch than the rubber does.
LunchboxCritter
- 91 NA to J-Spec TII
- 88 FC Vert
- 04 Rx8
Disclaimer: I am not a mechanic, and I did not sleep at a Holiday Inn.
DO NOT TRY THIS AT HOME!!!
LunchboxCritter is offline   Reply With Quote
Old 11-22-2010, 04:43 PM   #3
sv51macross
SG Imports closes @ 5:30 and I need to prep for class. I'll return the 5mm stuff tomorrow and grab some 3.5mm. I fantasize about the semi-pp 4-port I have planned...sigh.
Old 11-22-2010, 05:43 PM   #4
LunchboxCritter
Simply Rotarded
It'll be worth all of the trouble.
LunchboxCritter
- 88 FC Vert
- 04 Rx8
Old 11-22-2010, 08:02 PM   #5
sv51macross
The semi-PP 13B or the silicone hoses? I have no damn doubt that silicone hoses will be worth the effort. But Lucy's hear needs a rebuild soon anyway, and I want her back together ASAP, so I won't wait for the nice stuff right now.
Old 11-30-2010, 03:04 PM   #6
Rotary Related
Good stuff at low prices
Rotary Related's Avatar
Rotary Related is on a distinguished road
it's the 3.5mm for the small hoses. If you go to autozone they don't have metric hose usually, just fyi.
Visit us at: www.rotaryrelated.com or find us on facebook
Rotary Related is offline   Reply With Quote
Old 12-14-2010, 07:53 PM   #7
Yeah, they have 5/16" rubber hose, and that size fits a bit loose, so you need to zip tie each connection.
The 3.5mm silicone stuff works the best for cars IMO.
