Old 10-27-2010, 11:07 PM   #16
NoDOHC
NoDOHC's Avatar
You should be above 200 WHp by 7,000 rpm. The old engine in my car did that with a cleaned-up stock port, factory manifold, factory ignition, and 8.2:1 polished turbo rotors. I also use a mustang dyno - you can't improve on steady-state loading...
I think that the carbs are running very rich. I always had trouble getting a carb to run at all with vacuum if I leaned it up enough to make power at WOT.
I really like fuel injection.
Still, there is something to be said for old school.
Old 10-28-2010, 06:08 AM   #17
Buggy
I've been Wankeled!
Buggy's Avatar
Buggy is on a distinguished road
It is running perfectly fine as far as AFR's go. We had it hooked to a wideband on the dyno as well. If I remember right it was in around the 12's or 13's. The big problem is the carb and intake. A 48IDF is too small for the engine its on and the intake isn't the best flowing intake ever made. Also my exhaust isn't ideal for power. I traded maximum flow for my hearing. The first exhaust I built for it made far more torque down low but I just could stand it and neither could anyone else (like the cops).
1976 Rx-4 hardtop. Half bridge 3B 13B, S5 NA rotors, Renesis e-shaft, stat gears, and bearings, balanced rotating assembly, RE dual weber 36 DCD's 203rwhp 137ft-lbs torque DGRR 2011 3rd place
1974 Rx-4 all original 27,000 miles
1988 Rx-7 TII 320rwhp. DGRR 2012 3rd place
Buggy is offline   Reply With Quote
