Old 10-18-2010, 11:24 AM   #1
sen2two
KTEC
sen2two's Avatar
51 IDA on 12a, not PP...
I just bought a 85 gs with a 12a and it already has a RB manifold and Holley. Not sure if its a RB 465 or a 600cfm holley. The guy I got the car from bought it as is and didnt know, and from what i'm told... i can bet it's a 600.
So, I have these 51 IDA webers with a IDA 12a manifold... I know a holley 600 is far to large for a stock or street ported 12a. But I have had them run fine with the over sized holley before. So is that to say, I can use my 51 IDA, even know they are to large, and get them to run good until i get get a nice 45 or 48 IDA?
Or is a 51 just so over sized it will never even come close to running right?
what I have:
What I had:
Old 10-19-2010, 07:30 AM   #2
t_g_farrell
Waffles - hmmm good
t_g_farrell's Avatar
It will depend on the chokes you have in the 51. If its a stock port 12a you will
need to have a choke down in the 37-38mm (or whatever increment Weber
chokes come in thats close to that) for decent idle at a reasonable rpm.
Otherwise it will have to idle up high to keep running to get the velocity it
needs due to the size of the weber.
Old 10-19-2010, 01:50 PM   #3
730RWHP12A
the 51 will work fine, like tj said simply install smaller chokes and it will drive great
rotaryshack.com
Old 10-19-2010, 03:50 PM   #4
Buggy
I've been Wankeled!
Buggy's Avatar
Buggy is on a distinguished road
Agreed. That's one nice thing about the weber carbs, you can change the venturi/chokes to configure the carb to work with pretty much anything.
1976 Rx-4 hardtop. Half bridge 3B 13B, S5 NA rotors, Renesis e-shaft, stat gears, and bearings, balanced rotating assembly, RE dual weber 36 DCD's 203rwhp 137ft-lbs torque DGRR 2011 3rd place
1974 Rx-4 all original 27,000 miles
1988 Rx-7 TII 320rwhp. DGRR 2012 3rd place
Buggy is offline   Reply With Quote
Old 10-19-2010, 05:27 PM   #5
sen2two
KTEC
sen2two's Avatar
Now i am pretty new to webers. I have owned a few, but never took them apart. How would I go about swapping out the chokes?
Where would I get the smaller chokes also?
what I have:
What I had:
Old 10-20-2010, 10:26 AM   #6
730RWHP12A
ill check and see if i have some. to remove them, remove the carb top,remove acc pump nozzels, then slide out the aux venturies, then slide out the venturies/chokes. its real easy .
rotaryshack.com
Old 12-06-2010, 07:35 PM   #7
sen2two
KTEC
sen2two's Avatar
Did you ever check to see if you had any?
what I have:
What I had:
Old 12-15-2010, 10:51 PM   #8
730RWHP12A
i found some 37mm they are in a 48 IDA i recently acquired. it came off a 12A
rotaryshack.com
Old 12-16-2010, 09:15 AM   #9
sen2two
KTEC
sen2two's Avatar
Sorry, found another set already. Wasnt sure if you were going to reply. Thanks though.
what I have:
What I had:
