Old 10-18-2010, 07:16 PM   #1
dr50376272
dr50376272 is on a distinguished road
13b turbo to N/A Are the series 4 13B turbo motors as the naturally aspirates serie
13b turbo to N/A
Are the series 4 13B turbo motors as the naturally aspirates series 4/5 motrors the same except for compressed rotors? can i chuck in N/A 13b rotors in a 13b turbo engine and all will be fine? ill be losing the turbo and periperal porting.
ill also use the 13b turbo manifold to get EFI.
regards
David Robertson
Japan 899-4332 kagoshima ken
kirishima shi kokubu chuou 1 choume
12-11-1
デイビッドロバートソン
899-4332鹿児島県霧島市国分中央1丁目
12-11-1
my car: www.kagoshimaenglish.com/rx4.htm
dr50376272 is offline   Reply With Quote
Old 10-18-2010, 07:39 PM   #2
tweiss3
Mazda Lover
tweiss3's Avatar
The compressions are different
Old 10-18-2010, 11:37 PM   #3
dr50376272
read
so if i change the rotors from low to high compression, then i can run the engine N/A right?
Old 10-18-2010, 11:54 PM   #4
730RWHP12A
yes
rotaryshack.com
Old 10-19-2010, 10:58 AM   #5
RotorDad
Big Ugly
RotorDad's Avatar
You can still run boost on all of these, just get your tune right. As far as the rotor specs I believe it goes like this.
13B rotor comparison:
1974-1978 / 9.2:1 @ 11.58 lbs
1984-1985 / 9.4:1 @ 11.58 lbs
1986-1988 NA / 9.4: @ 10.04 lbs
1987-1988 Turbo / 8.5:1 @ 10.04 lbs
1989-1992 NA / 9.7:1 @ 9.54 lbs
1989-1992 Turbo / 9.0:1 @ 9.54 lbs
1993-up Turbo / 9.0: @ 9.54 lbs
Renesis 2004-up / 10.0:1 @ 9.30 lbs
Boosted Big Body On 335's
PS3 ID: Rotordad
Old 10-21-2010, 09:52 PM   #6
NoDOHC
NoDOHC's Avatar
The 13b turbo manifold will not work with a peripheral port.
Otherwise, make sure that your entire rotating assembly is from the same series at a minimum.
Old 11-03-2010, 05:06 PM   #7
rxspeed7
The fan hit the shit!
rxspeed7's Avatar
rxspeed7 is on a distinguished road
Also whatever series and style(turbo or N/A) you have to run the appropriate counterweights and front rotating assemblies that came with that series.
Zack.
rxspeed7 is offline   Reply With Quote
