#16 | |
http://www.mazsport.net/store/index....t_detail&p=140
93 bb rx7 Destined to be the never ending project car or possible part source for the rotary rat rod 2008 40th Anniversary Edition RX-8 - bankruptcy owned me RE-Amemiya Super Dolphin Tail Exhaust-for sale AutoExe Front and Rear Strut Bars-for sale AutoExe Member Brace Set-for sale 2008 Honda CBR600RR - bankruptcy owned me Motivation axle/fork/barend/frame sliders ASV "unbreakable" shorty levers Tripage Integrated Tailight and Adj FE Proton Fushmounts Akrapovic Hex Carbon/TI Slip On Sato Rearsets |
#17 |
Rep Power: 10 ![]() ![]() |
Dang! Thats bit too much..
I was thinking about putting HKS Twinpower on the 8.. I have an extra one for the Blk FD and thought about installing it.. Has anyone done this??
#18 |
You should be able to use the HKS ignition without any problems at all, however most of the problems with the rx8 are with the coils which is why mazspeed made the upgraded coil ignition system.
#19 |
KONI Challenge Crew
Thumbs down for Mazsport!!! They are way overpriced on everything they "make" and sell.
04 TiGray RX8 MT, LS2 coil setup, 3" midpipe, HKS Hi-power 3" exhaust, TEIN S-Techs, Hotchkis Adj F/R sways, K&N Typhoon V2, Steel braided brake lines, Redline drivetrain fluids, ATE Super Blue brake fluid, Cobalt XR2/GTS brake combo, MB Motorpsorts Weapons 18x9 +45 offset, 275/35's
#20 |
good to know, I've never delt with them personally just had heard people talk about the coil setup they do.
#21 |
You can also use GM's Ls1 and Ls2 coils or MSD's 8247, though this are not direct plug in the work needed to make them fit seems fairly simple.
#22 |
Thought I'd follow up on this.
I took my 8 to Rosenthal (finishlineperformance) the day before DGRR08 and had them do this flash. I was already running premix so I wasn't concerned, just thought I'd get it on the latest version. I netted 24.6MPG on the drive home to VA which is the best the car ever got. Not saying the flash did that, but it MAYBE played a factor. Also, I spoke to RB yesterday as I'm getting their flash this month and wanted to be sure the recent mazda flash would not interfere. They reassured me that it wouldn't. They said they dont even touch those same areas that Mazda's flash does. Also, they get the latest flashes from Japan before the general public does, so they build off the most recent versions. Must be nice to be "in" with mazda
#23 |
BTW - I should have my 8 dyno'd end of May before the flash and after, I'll be sure to post results.
