Old 07-09-2009, 12:11 AM   #16
Bryan@BNR
Bryan@BNR is on a distinguished road
whats hillarious is your taking a front engine car and making it a mid engine car by putting the engine further back than the strut towers. That thing will handle much much better.
Bryan@BNR is offline   Reply With Quote
Old 07-09-2009, 09:33 PM   #17
stezhead54
stezhead54 is on a distinguished road
Thanks for all the help everyone. I've got a major issue to tackle now though. I've got a couple of pictures of the issue....anyone have some ideas?
stezhead54 is offline   Reply With Quote
Old 07-10-2009, 01:39 AM   #18
rotaryextreme
i like spinners
rotaryextreme's Avatar
rotaryextreme is on a distinguished road
Does that mean that the RX8 is a mid engine car, it's engine is basically behind the strut towers...lol
The ingenious and decidedly weird Wankel rotary engine works by using internal combustion to bounce a fat metal triangle around inside a hollow metal kidney bean, which hula-hoops around a central shaft to generate power.--- Jalopnik www.rotaryextreme.com, after more then a 2 year break, Rotary Extreme Re-opens 9/11/08.
rotaryextreme is offline   Reply With Quote
Old 07-10-2009, 02:32 AM   #19
need RX7
Clean S4 Nutswinger
need RX7's Avatar
'Front-Midship' FTW
Old 07-10-2009, 05:16 PM   #20
Bryan@BNR
That is correct.
Old 07-10-2009, 07:12 PM   #21
classicauto
crash auto?fix auto
classicauto's Avatar
Your tire is hitting your fender? I don't understand what the problem is.
Old 07-11-2009, 12:58 AM   #22
stezhead54
The problem would be the fact that the tire is sitting on the bump stop right now, so i've got no where for the tire to travel but down. So i'd be riding on the frame, which is not something i really wanna do for a daily driver.
Old 07-14-2009, 10:12 PM   #23
stezhead54
So I've come across two more questions about my install. They can both be answered at the same time though. They would be...which set of injectors are the primary, and which are the secondary? Also which rotor is considered the first one?
Old 07-15-2009, 02:11 PM   #24
classicauto
crash auto?fix auto
Raise it up a bit? Maybe some spring blocks if you're feeling ghetto
Primaries are located in the irons on the engine, the secondaries are in the lower intake manifold.
First rotor = closest to the front of the car.
Old 07-15-2009, 09:03 PM   #25
stezhead54
Thanks....i'm all wired up now except for the coils. those will be hooked up and ready to go in a couple days. So it looks like things are gonna go pretty smoothly for the next week or so. I've got the engine out of the car again so i can weld in the engine mounts. Can't wait to get them built and in place :-D Then it's just exhaust, and drive shaft, and i'm set :-D
Old 09-10-2010, 01:39 PM   #26
stezhead54
For all those who are interested, the car is about 3 steps away from completion (drivability wise anyways). I only have to put in a small section of exhaust pipe, and some oil cooler lines, and finalize the gauges and wiring for the engine, ant it's all set. I'll be putting the updated pictures on here tonight when I can get to an actual computer. I've still got a lot of work to do on the car yet though. I've got dents and dings that I need to fix, along with the final paint job thats going to go on it. Then I'm also redoing the inside, so that's going to be some more work. I'm excited though, I'm actually able to see some progress.
Old 09-10-2010, 10:59 PM   #27
NoDOHC
NoDOHC's Avatar
Have you had it running yet?
Is the 20B really heavier than the 305 that was in there? The suspension being on the bump stops would tend to indicate that it is. A fully assembled 305 weighs about 450 lbs, surely a 20B doesn't weigh that much... even with a turbo.
Old 09-11-2010, 04:08 AM   #28
RotorDad
Big Ugly
RotorDad's Avatar
Now this is an interesting swap, I would like to see the finished product. The look on the faces of the American car guys will be priceless.
Boosted Big Body On 335's
PS3 ID: Rotordad
Old 09-12-2010, 08:40 PM   #29
D4rw1n
Sham-POW
D4rw1n is on a distinguished road
ive always wanted to put a rotary in an american ride. Seems like pay back for all the v8 fd swaps.
93 VR Fake R1
PFC + LC-1 + Datalogit
Full Non-Seq @ 12psi
KGparts Diff Brace
Fluidyne Radiator
Tri-sports AST
SS DP + MP + Catback
Poor Mans Air Box Mod with K&N
Walbro Fuel Pump
http://fah-web.stanford.edu/cgi-bin/...teamnum=162255
D4rw1n is offline   Reply With Quote
