Old 03-31-2008, 06:52 PM   #1
FRFC3S
FRFC3S is on a distinguished road
Bad idle, Hesitation under load, black smoke
FRFC3S is offline   Reply With Quote
Old 03-31-2008, 07:16 PM   #2
J-Rat
J-Rat is on a distinguished road
Jesus! Might just want to go ahead and slave in a spare ECU and see what happens.
1988 10th Anniversary
554 RWHP, 395 RW Torque
10.7 @ 126!
owner:
www.azrx7.com
Engine built by ARIZONA ROTARY ROCKETS
www.azrotaryrockets.com
J-Rat is offline   Reply With Quote
Old 03-31-2008, 07:23 PM   #3
FRFC3S
Old 03-31-2008, 07:28 PM   #4
Rotary_Rocket_87
2nd Generation Freak
Rotary_Rocket_87's Avatar
Check to see if all the electrical connectors are tight under the hood. My car did something very similar to yours cause the TPS and AIT sensors had come unhooked.
Old 03-31-2008, 10:33 PM   #5
FRFC3S
Old 03-31-2008, 10:49 PM   #6
J-Rat
Actually, you would have to check the voltage after the resistance drop, with the red lead on the proper pole of the sensor and the other lead on a chassis ground.
10.7 @ 126!
owner:
www.azrx7.com
Old 04-01-2008, 01:07 PM   #7
FRFC3S
Thank you J-Rat. I will try that and I will try retiming it and get back to you guys. Please post any further ideas.
Old 04-01-2008, 01:38 PM   #8
Ender
rotors excite me
Ender's Avatar
http://www.rotorwiki.com/index.php/TPS_Adjustment
Make sure you use the S5 instructions. Your TPS could be bad, and a reading of '1', with the 1 being all the way to the left of the multimeter screen, means that the resistance is either infinite (meaning no continuity, no connection) or you are using too low of a setting. If it's '1' all the way to the right then you are probably using too high of a setting on the meter and you should turn it down until you get a non-one reading or you are as low as it will read.
'87 TII
rTek 2.1 awaits a tune
Originally Posted by need RX7
360 gamertag: quick Tii
Old 04-01-2008, 10:00 PM   #9
FRFC3S
Old 04-01-2008, 10:34 PM   #10
Ender
rotors excite me
Ender's Avatar
I did, it's just that the TPS can be problematic even if it seems to test out ok. I and others have had it happen before.
You may be on to something with vacuum leaks, they're very common and can cause really weird problems. I found the most help from a tool that plugs the intake and has a pressure gauge mounted to it, you can pressurize the intake with the adapter that's on it. I tried a few different methods of finding vacuum leaks and none of them were a fourth as effective as doing it with this tool:
http://boostpro.net/prodtester.html
You'd want one of these two for the best results:
Boost Leak Tester (Gauged)
3" Diameter
With Tire Valve Adapter
$20 + $4.60 shipping
3" Diameter)
With Male Compressor Coupler
And here's a DIY option that you can modify to make work for the '7:
http://www.supercar-engineering.com/...T/IntPresTest/
'87 TII
Old 04-02-2008, 05:57 PM   #11
FRFC3S
Old 04-02-2008, 06:47 PM   #12
FRFC3S
Old 04-03-2008, 08:32 PM   #13
FRFC3S
Old 04-03-2008, 09:29 PM   #14
I am under the impression that if the boost sensor is bad, it would thrown the CEL. Is your light on?
Also, I have never heard of the the boost sensor failing (on its own) on an FC.
Oh, and I don't have that many CEL codes on my S5 emissions removal.
Old 04-03-2008, 10:17 PM   #15
you can use a n/a ecu... you just drive easy and can't boost... that would be a good way to test the engine lights..
