Old 08-11-2010, 06:41 AM   #1
soldave
soldave's Avatar
soldave is on a distinguished road
Is this a lightened flywheel (inspection plate pic included)
Am planning a clutch swap this weekend in my '91 S5 Tii and tonight was just making sure I had everything. Clutch: check, lightened flywheel: check, bearings: check. Then I realise that lightened flywheels need a counterweight for the flywheel. Remembered that the previous owner of the car said his butt dyno and knowledge of having a few FCs before said that there could very well be a lightened flywheel in there, but he couldn't say for sure as it would have been put there by the previous owner.
I dropped under the car, whipped off the inspection plate and took a pic. I've no real idea what I'm looking for, but you can see the flywheel in it. Apologies if this is a dumb question but does it look like a stock or aftermarket flywheel to you? If I need to clean it all up, let me know.
Cheers in advance
Big in Japan: soldave.ismysite.co.uk
soldave is offline   Reply With Quote
Old 08-11-2010, 06:57 AM   #2
To_Slow
Looks like OEM...
My link
Old 08-11-2010, 09:21 AM   #3
730RWHP12A
no. thats a stock flywheel
rotaryshack.com
Old 08-11-2010, 10:06 AM   #4
soldave
soldave's Avatar
Damn you both and your bad news! Looks like a desperate search for a counterweight in the next 48 hours then. Think this has been discussed before, but an FD counterweight will work with an S5 Tii, won't it?
Old 08-11-2010, 11:36 AM   #5
While you are down there, fix that oil leak as well. Nasty.
Old 08-11-2010, 05:56 PM   #6
Yep, I have to agree that it's stock.
That is correct.
The rotors are the same weights and counterweights are interchangable.
