| View Poll Results: Which ignition setup would you go for? | |||
| LSx Coils with bulkhead fittings through the firewall |
0 | 0% |
| Coil on plug |
0 | 0% |
| other (please explain) |
4 | 100.00% |
| Voters: 4. You may not vote on this poll | |||
#16 |
ORD - Old Rotary Dude
In this current build that I am doing for my son's TII, I am bypassing the J109s and getting the signal direct from the wiring. This signal will be then fed into the DR100 ignitors (2 leading and 1 trailing) then dispersed accordingly. Direct fire on the leading and back to the distributor for the trailing. It has been an odd experience to be working on a distributor based igntion in an FC.
