| Rotary Diagnostics Systems Our Rotary-engine Compression Testers combine off-the-shelf hardware and software to create a reliable system that can be used to obtain accurate engine compression measurements from a rotary engine. www.rotarydiagnostics.com P.O. Box 524 Mont Alto. PA 17222 (717) 352-7096 |
Administrator
Rep Power: 10 ![]() |
Rotary-engine Compression Tester Systems
I would like to thank Larry at Rotary Diagnostics Systems for his support of RCC! His contribution will go towards the promotion of this forum at Seven Stock XIII In September.
Check out his website www.RotaryDiagnostics.com and feel free to post questions for more information on his Rotary-engine Compression Tester Systems. Thank you! Our Rotary-engine Compression Testers combine off-the-shelf hardware and software to create a reliable system that can be used to obtain accurate engine compression measurements from a rotary engine. Figure 1. Model ReCT-TRT, Two-rotor Compression Tester System. The Processing Unit includes an enclosure containing the analog-to-digital converter, DIN data sockets for 2 Acquisition Units, plus the power and data connections. Power and USB cables, as well as the programs CD are a part of the Processing Unit. The Processing Unit receives analog signals from the Acquisition Units during a compression test and converts them to a digital data stream for transmission to the computer for recording and later display and analysis. The Acquisition Units consist of precision pressure transducers with attached 30" cable and DIN connector, a spark plug hole adapter with swivel air plug, and a quick coupler fitting for easy connection of the components. Last edited by ZGN; 07-14-2010 at 06:10 AM. |
Rep Power: 20 ![]() |
Nice! I looked at the site real quick but didn't see a price. How much is this one?
#3 | |
Compression Tester Man
Rep Power: 17 ![]() |
Larry |
