Old 06-24-2010, 04:40 PM   #31
i dont have an rx7 with a speedo... my gearing is all 4.78 anyway.
Old 06-25-2010, 02:26 AM   #32
Originally Posted by sen2two View Post
Found this for the people wanting to do a T5 swap... good general info.
http://www.flatheadv8.org/ernie/ernie-t5.htm
Also, the Rx8 diff internals do fit into TII casings with no modification, correct?
No, not even close, no fucking way, totally different box's
Old 06-25-2010, 10:50 AM   #33
sen2two
KTEC
sen2two's Avatar
are you refering to the diff or the tranny in my post?
I was only told this. Never seen the Rx8 diff in person, so that's why i asked...???
what I have:
What I had:
Old 06-25-2010, 07:41 PM   #34
Both The carrier itself I BELIEVE is interchangeable but the pinions etc are not.
Old 10-22-2010, 08:07 PM   #35
slidinsilly
slidinsilly is on a distinguished road
i have an 87' NA with a welded rear end. do you have any info on what happens to the mounts that make it bang around? thanks
slidinsilly is offline   Reply With Quote
Old 10-22-2010, 10:53 PM   #36
sen2two
KTEC
sen2two's Avatar
welded diff is a no no...
But anyways, There are two diff mounts that bolt the rear of the diff to the body. Then there is a mount up front that bolts the nose of the diff to the sub-frame. This is most likely your problem. Search my name on here in the 2nd gen section and you'll see what I did to solve this problem.
what I have:
What I had:
Old 10-23-2010, 04:34 PM   #37
slidinsilly
thanks for the quick response. thats the only mount that i didnt buy from racing beat the other day. the other tech at my work said to check the u joints. could this also be a problem?
edit: could you also post a link to the post u were talking about i cannt find it
Old 05-15-2011, 08:33 AM   #38
rotaryracer
rotaryracer is on a distinguished road
4.78!!!!!! Thank you for the info. I currently drive an '83 race car and auto-x/rally-x a bone-stock '87 TII. lots of useful info.
rotaryracer is offline   Reply With Quote
Old 05-16-2011, 12:24 AM   #39
Renesisking
Renesisking is on a distinguished road
Incredible work man.
2004 RX-8. I would love to tune it but can't find the right parts for Microtech
Renesisking is offline   Reply With Quote
Old 08-11-2011, 06:07 PM   #40
Update:
http://kennedyenginc.com/OtherAdaptions.aspx
