Old 05-23-2010, 08:22 PM   #16
Well the digital dash is already a certain. I need to verify the inputs first and what I can afford. Consequently from the stock sensor suite does the FC have Oil Temp?
No it doesn't. There are a bunch of options for mounting it though. I have the first produced RE-Speed adapter tower with the -10AN fitting on it for both pressure and temp. You could also just use a generic -10AN coupler with an 1/8" npt port. I would kinda prefer to know what the temp is as it exits the engine, rather than as it goes back in. I think that information would be more usefull even if it is scary as hell.
I don't have a Low coolant sender that works anymore (Ruined my low coolant sender when I attempted to mount it to my old radiator--may pick up a new one and try to find a nice round stock and actually get it drilled and tapped for the proper threads this time),
Stock one won't work. You'll need to get something that latches to grnd.
I'll also need to figure out if my low sump sender works anymore (some reason I don't think it does).
Same thing, need something that latches to gnd.
Fuel Pressure... I think I might hold off on that (as it would require purchase of a new sender).
Suck it up man, get the AutoMeter replacement senders. They're Delco or Dephi replacements for like $90. It's good info to have ESPECIALLY on a boosted engine. You know my history. With pressure vs MAP you can make a correction table that could keep you from chunking an engine.
Quick question: Can Digital Pulse Inputs (DPI) be used as a Digital Switch Input (DSI)?
On the MoTeC's - yes
Alright, another question for the general community: How does the Digital Dash hook up to the ECU? I'm assuming via the CAN bus system, but after going through both the dash manual and the ecu manual I don't see any instructions on installation to the ECU.
CAN bus is the way. Setup is specific to the combination. Which dash are you going with?
Here's the link to the spreadsheet I've done. It's still quite rough, but adjustments might be needed here and there.
http://spreadsheets.google.com/ccc?k...LMHIxcHc&hl=en
I'll check it out in a bit..... going to weld a fuel cell
Old 05-23-2010, 09:36 PM   #17
Okay, I'll add it to the list of crap I need to buy still.
SOB... alright, well add another to the list, I think I'll be saying this a lot.
+1 to list.
to the list it goes
For future reference so does the Platinum series ECU's from Haltech.
I'm just going with a simple Racepak IQ3 display dash (no logging capability built in to it), but it does has some nice features for not tons of money.
I want to TIG too! GL with it! No contaminatin' the metal with your man juices now.
Old 05-24-2010, 05:49 PM   #18
Hey B,
what sensor are you using for sump level? I've found some SS floaters for around 100, but I think that might be over kill.
Old 05-24-2010, 06:50 PM   #19
floaters...
Using the stocker
Old 05-24-2010, 07:24 PM   #20
floaters...
Using the stocker
I thought you said it had to be two wire? Doesn't the sender only have one? I'm so confused.
Old 05-24-2010, 09:49 PM   #21
Well, I'm going to try the liberal/dem approach here and say, well, yeah I said that, but I didn't really mean it
The stock sender must ground itself through the oil pan because when than circuit closes it latches to gnd. I've got that wire hooked to a digital input
Old 05-24-2010, 10:18 PM   #22
project86
Can't.Make.Up.My.Mind.
project86's Avatar
Vex... He convinced me to go MoTeC... youre just delaying the inevitable
But HOT DAMN!!! I cant deny its pricey. Haltech was my second choice. I have had some local experiece with it and it seems solid and very capable. The guy is running the E6X though. I think the new Platinum series is even more capable though.
'90 GTUs
'06 Toyota Highlander Hybrid
'10 Toyota Prius
Old 05-25-2010, 11:16 AM   #23
Yeah, I'm going to run a PS1K (I'll have all the inputs/outputs I'll need)--for now. Factoring in my timeline for my final plans with the car there's really no need for me to go Motec now (later... yes... maybe...depends on technology).
As for my sensors I think I have an easy question that will put my confusion to rest:
Out of all the stock sensors what can I keep, and what must I replace?
What I know I can keep:
Low Sump Level--May need some work
Coolant Temp Sender
Thermocouples (will need amplifiers)
Wideband O2 Sender/Controller
What I know I need to buy:
MAP
Low Coolant Sender
Oil Temp Sender
If it's not listed add it in.
