Old 05-10-2010, 03:05 AM   #1
Kim
OBEY YOUR MAZDA
Kim's Avatar
Kim is on a distinguished road
Racing Nikki issue
Hey Guys
I have a racing Nikki on a streetported 12A.
Well the thing is, as soon as the engine is running it feels like the throttle has to overcome a very strong vacuum, I really need to press the pedal hard to overcome the "binding"
Any inputs are appreciated.
Kim
Kim is offline   Reply With Quote
Old 05-10-2010, 10:11 AM   #2
Kentetsu
Kentetsu's Avatar
There is a part of the linkage that looks like a rod with a spring on it. This is supposed to rest on a pivoting "hook", but is often left loose and allowed to drop down. This is referred to as the "teeter totter". If you conduct a search, you should find info on it. This is you most likely suspect.
You can also do some more research over at www.sterlingmetalworks.com , where there is a wealth of information on Nikki carbs.
Good luck.
Old 05-10-2010, 12:55 PM   #3
Kim
OBEY YOUR MAZDA
Kim's Avatar
Only sprung rod on this carb is for the acc.pump
The problem is only when the engine runs, when it's shut off - no problem.
Primaries and secondaries open together.
Old 05-11-2010, 11:44 AM   #4
orion84gsl
If I'm not mistaken you should be using the black spacer between the manifold and carb.
Old 05-11-2010, 12:24 PM   #5
Kentetsu
Kentetsu's Avatar
Either you are psychic, or there are photos that I cannot see.
Old 05-11-2010, 03:11 PM   #6
I was just going to suggest that.
You can't see the pics??
Old 05-11-2010, 06:25 PM   #7
Kim
OBEY YOUR MAZDA
Kim's Avatar
Hmm - thanks guys.
How could I forget about the spacer
Old 05-15-2010, 09:00 AM   #8
orion84gsl
Let us know if that works out for you.
Old 05-15-2010, 02:52 PM   #9
Kim
OBEY YOUR MAZDA
Kim's Avatar
I will check it in the week to come, racecar is at my friends place. Thanks
Old 05-17-2010, 09:33 AM   #10
Kentetsu
Kentetsu's Avatar
Yeah,the filtering at, um, the place I'm at right now, won't let the pictures through if they are hosted. If the pics are uploaded to the site, then I'm fine.
