| 2nd Gen RX-7 Engine Parts Only Engine Related parts ONLY! |
RTRY-FTW
WTB: S4 front chassis harness
complete. to clear which harness this is it is the main harness in the front of the vehicle starting at the fuse panel, runs across the inside of the firewall to the ECU, then from the fuse panel exits the firewall on the drivers side and has connections for the coils, headlights ect.
Not sure if this would be considered engine or interior specific. LMK what you have. Thank you
1988 S4.5 TII JSpec swap Coupe 1988 S4.5 TII JSpec swap Vert 1995 S14 DDD |
Rep Power: 17 ![]() |
i'm about to drag up a s4 this week to part out i'll let you know how it goes.
Simply Rotarded
Do you know if an S5 J-Spec one would help you out? If so PM me and I'll let you have it for what it costs to ship it to you.
LunchboxCritter - 91 NA to J-Spec TII - 88 FC Vert - 04 Rx8 Disclaimer: I am not a mechanic, and I did not sleep at a Holiday Inn. DO NOT TRY THIS AT HOME!!! |
Rep Power: 21 ![]() |
relatedly, i am in need of an engine harness if anone has one laying around pulled. Im avioding having to go pull one at the jyard
RTRY-FTW
would not work, everything is routed on the wrong side. thank you for the offer though
I have a s4 na harness if someone wants It I could bring it to the dragon tomorrow...
S4 INTO S5 Turbo II OWNER
i have one from an 87 in box with all sensors i believe .. 100$ + shipping.
