Old 03-28-2010, 11:53 AM   #1
Pettersen
Norwegian S4 Base TII
The car is a 1986 Base with 140K miles on the body and 6k on the engine since last rebuild, wich i bought 1.5.2010.
list of mods when i bought it:
Koni struts pressure adjustable
Lowered
88 T2 engine with streetport and T70 turbo. running 7psi.
Removed PS and AC.
T2 brakes
T2 Diff
Power windows
Custom front and rear strut braces.
Custom Stainless 90mm downpipe.
Custom Stainless 2*2.5" exhaust
32mm wastegate.
Ebay exhaust manifold.
custom hoodscoop welded on the steel hood.
17" winter rim's with 215/45R17 tyres
16" summer rim's unknown tyres:?
Walbro fuel pump
FCD
720cc secondary injectors
stiffer bushings in suspension
+ alot of stuff i don't know about or just forgot to mention.
Overview of my plans:
Eksterior:
Volvo 740 lip []
Front diffuser (planning on making it myself or getting it made out of aluminium). []
Rear diffuser RE amemya. []
General rust repair. []
FTP lence with driving light. [X]
Engine:
New IC. []
Haltech Platinium 1000. []
Electronic boost controller. []
100amp alternator [x]
Mount Vband and flex pipe on the downpipe []
Wideband. []
Interior:
Bride seats. []
New steeringwheel (Nardi?). []
Gauge's in the driverside A-pillar. []
Focal polyglass 6'5 speakers in doors. []
Focal polyglass 11" sub. []
Kicker zx650.4 amp. []
Stinger electrical end signal equipment. []
Feel free to leave a comment
Old 03-29-2010, 01:58 AM   #2
Wow, is that car running on the stock ECU? The fuel there must be very high octane if it did not blow up yet.
Old 03-29-2010, 09:32 AM   #3
Pettersen
runs on 91octane.
Also it has 720cc secondarys.
I don't see why it would blow up with the stock ecu just because of porting and a bigger turbo when i'm only running 7psi.
Old 03-29-2010, 12:59 PM   #4
Something about the extra amount of flow compared to the stock turbo at the same pressure level, causing it to go a bit lean. Do you have a Wide Band oxygen sensor to monitor the AFR ratios? I'm curious about how the afr's look under load.
Really, I'm just amazed to see this setup work, didn't know it was possible to run a different turbo w/o a standalone.
Old 03-29-2010, 01:45 PM   #5
Pettersen
No wideband yet. will get a haltech one when i buy the standalone.
Old 03-29-2010, 07:04 PM   #6
My5ABaby
My5ABaby's Avatar
Nice car. Those tail light rock.
Community Service Manual
RotorWiki
Old 04-04-2010, 01:00 PM   #7
Pettersen
Started on a sub box today,
Finished box, lacks mounting point, and i will also make a coverup panel to make it look like it could have been stock But for now it's ugly as sin...
I'm going to buy a 11" Focal 27v2 at some point(wich will be mounted with the magnet in to the box), but for now i made a spacerplate and mounted a old 12" sub i had layin around.
Old 04-05-2010, 02:37 PM   #8
Pettersen
Changed my mind and made new spacers for the old sub so it could be mounted with the magnet in to the box.
painted it black to protect against moisture.
Fits like a glove WHen i buy a new sub it won't build outwards so much.
started on amp and power cap mounting plate
Old 04-05-2010, 06:02 PM   #9
FC3S Murray
frustrated!
FC3S Murray's Avatar
BOOM BOOM baby!
Same pig, new soul
Old 04-08-2010, 02:26 PM   #10
Pettersen
Got the jspec ftp lights today
Old 04-16-2010, 06:10 PM   #11
Pettersen
Got the downpipe welded
I'm waiting for a new oil feed line, since the old one had seen better days.
Started on updating the ground points in the engine bay, will need to get some shrinkwrap so i can stop using the tape.
Old 09-11-2010, 05:44 AM   #12
Pettersen
The RX7 will be staying in theis garage while i finish my bachelor degree, so i have the oppurtunity to do a bit more extensive work than i first had planned
Picture time
Old 09-11-2010, 05:38 PM   #13
NoDOHC
NoDOHC's Avatar
The last shots look familiar, the interior is a pain on the FC, but it has to be fixed sometime...
I see you used the opportunity to run power to your subs - good idea, do it right and it probably won't short out and leave you stranded.
Looks good so far.
By the way Max777, the engine is typically the driving factor in air flow rate at a given boost level. With the intake air pressure (boost) kept constant, I can only think of two methods that the air flow rate through the engine could increase by merely changing the turbo:
Method 1: More dense air (cooler charge) due to a more efficient compressor. This actually helps the engine keep from detonating.
Method 2: Lower exhaust backpressure due to a more efficient turbine - decreases the exhaust reversion which lowers the intake air temperature... once again decreasing the tendency to detonate.
The project looks good!
Old 10-03-2010, 06:29 AM   #14
Pettersen
Found some more rust, and the worst i've seen on the car so far. Still it's not to bad for a car from 86
And on the bright side, i should become fairly good at welding once i'm done with the rust repair.
Old 12-27-2010, 05:58 PM   #15
Pettersen
Bought a present from me to me
