Old 03-25-2008, 05:11 PM   #1
one320fc
one Apex @ a time
one320fc's Avatar
one320fc is on a distinguished road
Question Question about 5th and 6th ports
So working on the GSL-SE, I cant imagine that my ports are opening due to my exhaust system. 2.5" from the factory manifold all the way back with a high flow cat. All the emissions are still intact. If this is a correct statement can I operate them with the air pump? or should I just wire them open? Thanks
one320fc is offline   Reply With Quote
Old 03-25-2008, 05:45 PM   #2
I say we race, lol... then you'll know if they're opening!
Old 03-25-2008, 06:19 PM   #3
one320fc
one Apex @ a time
one320fc's Avatar
dont want to hurt your feelings though
Old 03-25-2008, 08:07 PM   #4
My5ABaby
My5ABaby's Avatar
http://www.rotaryresurrection.com/2n...actuation.html
This is for 2nd gen's, but it might work for 1st gens.
Old 03-26-2008, 12:17 PM   #5
OH - its on now, lol....
Old 03-27-2008, 04:02 PM   #6
ratboy
ratboy's Avatar
ratboy is on a distinguished road
I tried to wire mine open but it is not nearly as easy as that sounds. I tested the actuators with a ~6 psi shot from my compressor blowgun. Since they snapped open nicely, I just found and fixed the leaky hose coming from the exhaust. If that didnt work I was going to go the air pump route.
ratboy is offline   Reply With Quote
Old 03-27-2008, 05:34 PM   #7
impulsive-RX7
impulsive-RX7's Avatar
impulsive-RX7 is on a distinguished road
Yes it is that easy.
impulsive-RX7 is offline   Reply With Quote
Old 03-28-2008, 09:08 AM   #8
ratboy
ratboy's Avatar
Even with the actuators held open (hit w/ air, then crimp hose to hold pressure) I couldnt get them secured well enough to stay open. Did you remove parts of the intake to wire them? Do I have abnormally large hands?
Old 03-28-2008, 09:43 AM   #9
impulsive-RX7
You should remove the actuators. Then you can turn the sleeves by hand, and tie them off in the open position.
Old 03-28-2008, 11:29 AM   #10
^ thats what I did on my FC years ago before going boost
Only issue is that they dont turn easily if they're stuck, which is what my gsl-se's issue is which means I have to take off the entire manifold setup and pull them out to clean them...
I'm debating about even putting them back in!
Old 03-31-2008, 09:29 AM   #11
ratboy
ratboy's Avatar
ahhhhh! Well I never saw that tidbit before, I was always wiring the actuators!
