Old 03-01-2008, 09:51 AM   #16
Good luck man!! I wish I was working on the 7, unfortunately I have to help a friend put a new cylinder head on a 92 Escort, and WP and timing belt. Piston engines FTL.
Old 03-01-2008, 11:53 PM   #17
SpooledupRacing
Guest
Posts: n/a
Ok so me and RX7tuner built the engine today... it was alot of fun, we had alot of laughs a few head scratchers and well something that just made us go WOW
but here it is as of tonight...
The control rings with the o-rings installed
Installed in the rotors
The rotors are all lubed up with Crisco
This iron has the o-rings installed and layered with crisco
umm yeah there I am .... with the shaft!!!
1 plate at a time
Getting closer
Together
assembled
I forgot to mention with my fingers in the plug holes and the engine turned over it had GREAT compression!!!
Old 03-02-2008, 05:34 PM   #18
87 t-66
87 t-66's Avatar
87 t-66 is on a distinguished road
thats pretty good..ive never seen anyone use crisco before haha
87 t-66 is offline   Reply With Quote
Old 03-02-2008, 05:56 PM   #19
SpooledupRacing
Guest
Posts: n/a
On the videos at www.pineappleracing.com he said to use Crisco.. so I guess some one does lol
here is some new stuff
Here are the pics I just took...
look at the layers
waste leaves here
The real deal!
Old 03-02-2008, 06:07 PM   #20
Rx7Tuner
Rx7Tuner is on a distinguished road
She is pretty.
l 1991 Rx7 N/A
l Fresh Rebuild with Streetport, Megasquirt 1 v3.0
l Emissions Removal, ACT S/S Clutch, Custom AAI,
l RB True Dual Exhaust, Tein Springs, TII Calipers
Rx7Tuner is offline   Reply With Quote
Old 03-02-2008, 08:29 PM   #21
SpooledupRacing
Guest
Posts: n/a
Thank you sir!!
Old 03-05-2008, 08:50 AM   #22
SpooledupRacing
Guest
Posts: n/a
Well last night I got my lim cleaned and painted... my crank pulley cleaned and painted.. my water pump housing is cleaned (painting tonight) and I plan to clean the uim tonight...
I will get pics tonight of everything done and the process as it unravels..
Old 03-10-2008, 05:51 PM   #23
need RX7
Clean S4 Nutswinger
need RX7's Avatar
updates?
Old 03-13-2008, 07:10 AM   #24
SpooledupRacing
Guest
Posts: n/a
The lim is bolted on
the exhaust manifold is completly stripped down and ready for high temp paint
the upper fuel rail has been painted (red)
the turbo was broken apart to clean and paint and I found the exhaust side was cracked inside.. (awaiting a new one)
still waiting for a clutch kit and flywheel
tonight I will paint the compressor housing (gunmetal)
tonight I will paint the lower fuel rail (red)
tonight I plan to paint the exhaust manifold (black)
tonight I plan to clean the uim and get it prepped for paint
next weekend I will send the injectors out to get cleaned and flow tested.
Old 03-13-2008, 08:13 PM   #25
SpooledupRacing
Guest
Posts: n/a
Time for updates...
since last time I have:
cleaned and painted the water pump housing
cleaned and painted both fuel rails
cleaned and painted the thermostat neck
pulled the turbo apart (found the exhaust housing is junk) clean and painted the compressor housing
mounted the upper intake
mounted the upper fuel rail (need to put injectors in of course)
put the water pump housing on (awaiting water pump)
here are some pictures
From a nice neat table to this mess
Old 03-14-2008, 10:25 AM   #26
Willub and Company
Willub and Company's Avatar
Willub and Company is on a distinguished road
looks very nice, make sure you take a video of the start up!
Christian's the name
10AE..BIG turbo and Microtech coming soon!
Willub and Company is offline   Reply With Quote
Old 03-14-2008, 10:56 AM   #27
SpooledupRacing
Guest
Posts: n/a
OH will do.
Old 03-23-2008, 10:18 AM   #28
SpooledupRacing
Guest
Posts: n/a
nothing really new to update.. I did however buy my ACT lightweight flywheel yesterday...
Old 03-24-2008, 01:54 PM   #29
SpooledupRacing
Guest
Posts: n/a
Well ACT's website is wrong.. the flywheel I bought will NOT work on my car so now I am out the time and money in order to get the flywheel and resell it then buy a new one to get the engine installed!!!
this is why I HATE ACT!!!!
Old 03-25-2008, 05:15 PM   #30
turbovert91
turbovert91's Avatar
turbovert91 is on a distinguished road
That sucks, you were making good time on the rest of your project, too...
turbovert91 is offline   Reply With Quote
