Old 11-16-2009, 02:59 AM   #1
Romulan_7
Romulan_7 is on a distinguished road
'85 12A Exhaust Issues
My car keeps burning out the collector gasket at the end of the exhaust manifold every couple of months. I'm thinking it's some kind of mixture issue, though I haven't gone through the effort to go chase it, so I'm not certain. I don't have any performance issues other than that, so I'd guess that the mixture wouldn't be far off if I'm right. As far as I know, the car has stock ports, and I know for sure it has a Nikki with the rat's nest intact, with stock ignition except for a couple of MSD coils. I run it on 87 octane without premix with Royal Purple 5W-30 in the sump.
Romulan_7 is offline   Reply With Quote
Old 11-16-2009, 10:16 AM   #2
Rogue_Wulff
Non Member
If it keeps burning that same gasket, I'd bet the mating surfaces are not true making for a spot that has little tension against the gasket. Either one of the mating surfaces is warped, or the pipe/manifold aren't lining up quite right.
If the gasket is always burning out in the same basic spot, start looking in that area for warped surface(s) or misaligned pipe.
Old 11-16-2009, 12:40 PM   #3
Romulan_7
Misaligned pipe would probably be it. My little rubber exhaust hangers are starting to wear out, so the cat/midpipe section is too low.
Old 11-16-2009, 11:20 PM   #4
rx7carl
rx7carl's Avatar
rx7carl is on a distinguished road
Are you using quality gaskets? If so Roger's advice is probably a good place to look.
www.pbandjracing.com
rx7carl is offline   Reply With Quote
Old 11-17-2009, 01:41 AM   #5
Romulan_7
Autozone gaskets, your mileage may vary. Thicker than the normal piston motor collector gasket with what looks like a metal o-ring around the inside of the exhaust hole.
Old 11-20-2009, 02:16 PM   #6
rx7carl
rx7carl's Avatar
I wouldnt trust anything but OEM Mazda gaskets on the exhaust.
Old 12-13-2009, 08:56 PM   #7
1stGenNutt
1stGenNutt is on a distinguished road
just jerk it off and place a header and straight weld it to a pre silencer and a good muff
take the cat to a scrap metal dealer and get some of your investment back
1stGenNutt is offline   Reply With Quote
