Old 11-08-2009, 09:19 AM   #1
hIGGI
hIGGI is on a distinguished road
20B oil specs
I have few oil related questions regarding 20B
- what is stock oil pressure?
- what oil pump does fit (20b only? or FD or FC oil pump?)
- anybody making oil pan baffle for 20B?
Thanks!
hIGGI
hIGGI is offline   Reply With Quote
Old 08-15-2010, 05:45 PM   #2
hIGGI
umm...what about bump?
Old 12-27-2010, 05:20 PM   #3
Akagis_White_Comet
Comealong busts your nuts
Akagis_White_Comet is on a distinguished road
Greeting hIGGI, I'm still working on my 20B. Since it's all stock, I'll be sure to get some oil pressure readings for you. My engine will have the stock FC sender on the turbo supply line, with a T-fitting there for a test port. The first start will have an external oil pressure gauge hooked up as well.
Pretty sure that FD uses the same oil pump. As for a baffle plate, that'd probably depend on if you're using the stock Cosmo oil pan (like I am) or a custom one (Christopher W.'s FC is). I know that Mazdaspeed has them for the stock pan Might suggest PMing GTORX7. (with the period) about what he'd suggest.
Akagis_White_Comet is offline   Reply With Quote
