Old 09-17-2009, 01:48 PM   #46
zayrx7
zayrx7 is on a distinguished road
it's a 13b turbo engine, hks t51 turbo
zayrx7 is offline   Reply With Quote
Old 11-07-2009, 10:09 AM   #47
jamespond24
jamespond24 is on a distinguished road
Originally Posted by charlies7 View Post
I dont really understand how so many people can spend upwards of 30k on there 20b swaps unless a shop is doing ALL the work.
If your smart and shop around you can easily have a killer NA setup for under 10k. However I am fortunate to use the resources at my university and from the local help with tuning and wiring.
Here is my break down if anyone is interested.
20b shortblock -- 1500 shipped, yeah I know I found a deal
20b rebuild -- all the goodies, heavy porting, balancing etc 4500-5000
(3) 13b housings -- price to be determined (prolly around 800)
Haltech platinum sport 2000 -- 1500
lS1 coils "smart coils" -- 150 bucks
Header -- 500 bucks in material (I did the fab work on it)
20b stock subframe mounts -- 100 bucks (again I did the fab work)
Electric meizere 55gpm waterpump refurbished -- 150 bucks
ITB's (untested) 250 bucks in material (again fabbed by me)
Misc. electronics, wiring, sensors -- 800
That is pretty much what I have into the car as it sits now. Its actually less than 10k more like 9k and everything is basically brand new. All the 13b related stuff I sold off almost covered the cost of the entire build so I pretty much broke even on a setup that will be more reliable, sound awesome, and make great power. I cant complain.
If you do the porting and rebuilding youself can save $4500 which is my plan for my 20B FC.
jamespond24 is offline   Reply With Quote
Old 11-30-2009, 11:04 PM   #48
Bryan@BNR
Bryan@BNR is on a distinguished road
Originally Posted by zayrx7 View Post
A full 20b install will run about $25,000 over here at www.rx7store.net. That price include single turbo, ported motor, clutch, fuel, computer and etc.
FYI! here is a teaser pic of a motor I'm working on right now, this will be one badass motor. I should have it done in about a week.
I think there is a slight problem with your custom intake port. If you think of fluid and air dynamics, both favor the path of least resistance (which would be your side port). The side port pictured is a medium/large street port. The extra rotor housing intake ports will just distort flow and kill air speed. A flow test you can do to see how the ports flow, take your water hose and spray the water in the port following the path of the lower intake runners. You will notice little to no water will be coming out of your rotor housing port. Water has the same flow charactoristics as air. IMHO I would either go with the standard street port or go with a peripheral port. One or the other. I would hate for you to waste your time, money and efforts on this project and it not work out.
Before anything, that exhaust sleeve needs to be replaced with the 13BT/rew rotor housing sleeve. Maybe you just haven't gotten to that .
Bryan@BNR is offline   Reply With Quote
Old 01-21-2010, 01:26 AM   #49
Rotary-Works
Rotary Vendor
Rotary-Works's Avatar
Rotary-Works is on a distinguished road
What happen after all,did the guy back out of the project?
www.Rotary-Works.com Now Open!!
1qwkrx3@gmail.com
Rotary-Works is offline   Reply With Quote
