Old 08-10-2009, 06:11 AM   #1
bbade
bbade's Avatar
Ball Joint - Grease
I took apart the front suspension to do some work and am getting ready to put things back together. I ordered replacement dust boots for the ball joints on the upper and lower control arms and plan to clean them up and put in some fresh grease. What type of grease should be used in ball joints? Is regular white lithium good or is there a specialty grease for automotive applications like this? Thanks!
Old 08-15-2009, 04:10 PM   #2
bbade
bbade's Avatar
Got a few responses elsewhere, but I figured I'd post the info here as well.
One suggestion was to use wheel bearing grease. I was also told that wheel bearing grease is lithium based and that white lithium grease would probably work fine for my purposes.
I went ahead and used white lithium grease as I already had some.
Old 08-19-2009, 11:02 AM   #3
IR Performance
Wheel bearing grease is fine. White lithium would NOT be good for this application.
www.irperformance.com
www.myspace.com/rotaryexperimentseven
irperformance@live.com
732-662-1794
Old 08-19-2009, 04:17 PM   #4
bbade
bbade's Avatar
Please elaborate. I have put everything back together already and would be very hard pressed to change out the grease by next weekend when I will be tracking the car. I am not an expert on grease by any means, does it not hold up well or something?
Old 08-27-2009, 04:29 PM   #5
bbade
bbade's Avatar
Ihor or anyone else that wants to chime in please elaborate on grease and its uses.
Old 08-29-2009, 04:37 AM   #6
rx4ur7
Rotary since 1972
rx4ur7's Avatar
I have used Kendall super blu for all wheel bearings, tie rods and ball joints in all client and race cars for nearly 40 years and never had a grease related failure.
Would not recommend anything that was not specific for wheel bearings. Yes there are lithiums that are high pressure wheel bearing specific. The white I have is not, and it works great for door slides and latches.
I would recommend changing it out especially if it is a track car. One time should not hurt anything. You may have to sacrifice a couple of boots though.
Then again if it is a quality grease and the manufacture specifications say that it can be used in ball socket joints then you should be all right. Especially if they can back it up with race proven or long term testing.
That is my two corner seals thrown in.
Old 08-31-2009, 01:03 PM   #7
bbade
bbade's Avatar
