Old 08-27-2009, 11:49 AM   #1
jerd_hambone
Senior Member/Lounge Rat
jerd_hambone's Avatar
Bucking, kicking, and screaming... Well sputtering...
So my car has a really odd problem. At completely random points in time, you will be driving and all of a sudden it starts bucking and kicking like you are tapping the gas really fast. It does it in every gear. If you try to floor it, it just falls on it's face and it is pretty much like you let off the gas completely.
I don't know what to do about this, and I can't figure it out.
Oh, in case you were wondering it's a 89 GTU.
1986 Luxury Package
1987 Luxury Package (sold)
1988 SE (sold)
1989 GTU (sold)
1990 GTU (sold)
jerd_hambone is offline   Reply With Quote
Old 08-27-2009, 02:02 PM   #2
and you've checked the TPS? All within specs?
Old 08-27-2009, 10:44 PM   #3
dudemaaan
dudemaaan's Avatar
how modified is the car? My car does it sometimes too, i have minimized it by tuning, but it still exists. I read an article explaining that the design of the rotary allows exhaust gases to mix with the fresh mixture in certain situations and it causes a misfire and results in the bucking. The technical name is 3:3 ignition mis-fire. here's a link to the pdf.
http://foxed.ca/rx7manual/manuals/RE...amoto-1981.pdf
Old 08-28-2009, 10:37 AM   #4
jerd_hambone
I forgot to add that the only way to stop it is to let the car set for 24+ hours and when you restart the car the next day to rev the holy mother out of it and it clears up.
I've not checked the TPS, I may have to do that.
1986 Luxury Package
1988 SE (sold)
1989 GTU (sold)
1990 GTU (sold)
Old 08-28-2009, 10:53 AM   #5
JL1RX7
Check all of your grounds. I know if they are bad or corroded that can lead the car to do some weird stuff.
Old 08-28-2009, 12:03 PM   #6
nvno1
FB 4life
nvno1's Avatar
nvno1 is on a distinguished road
Yeh the TPS will trip like that. Also have to changed the brand of gas you normally use.? I used some cheap gas one time and that was the last time that motor ran. not trying to scare you.
Dont be sorry, be careful.
nvno1 is offline   Reply With Quote
Old 08-28-2009, 01:42 PM   #7
jerd_hambone
I always use good gas, premium.
I've been thinking that it's the TPS, but figured I'd try to see what everyone else thought.
And it's not the typical bad ground bucking.
1986 Luxury Package
1988 SE (sold)
1989 GTU (sold)
1990 GTU (sold)
Old 08-28-2009, 02:32 PM   #8
JL1RX7
With NA you can use cheap stuff. 87 octane works just fine. Also did you check you battery cables and spark plug wires?
Old 08-28-2009, 07:45 PM   #9
jerd_hambone
Battery is getting juice, volts don't drop when it does it. The spark plug wires are about to get changed.
I used higher octane and the felt more peppy a tad and got better mileage. So I dunno.
1986 Luxury Package
1988 SE (sold)
1989 GTU (sold)
1990 GTU (sold)
Old 08-28-2009, 10:33 PM   #10
NoDOHC
NoDOHC's Avatar
My '91 likes premium more than regular.
My old '86 never cared at all, with the 8.2:1 rotors it really doesn't car now.
On the original topic: I had my '86 buck and shake once, but it was because I had the leading and trailing plugs connected backwards. Obviously, that doesn't come and go.
I am guessing that you have a bad connection or a fueling issue (loose sock or something).
This is an interresting problem, keep us posted.
Old 08-29-2009, 11:29 PM   #11
jerd_hambone
I will definitely keep it updated.
Today, the car wouldn't even stay running, it would just sputter and stall.
So I don't know haha
1986 Luxury Package
1988 SE (sold)
1989 GTU (sold)
1990 GTU (sold)
Old 08-30-2009, 09:25 AM   #12
TehMonkay
When you say it clears up the next day when you rev the piss out of it, it sounds like there may be way too much fuel. Have the injectors been cleaned?
Old 08-30-2009, 02:31 PM   #13
NoDOHC
NoDOHC's Avatar
Tehmonkey, Leaking injectors is the best theory I have heard yet. Dirt in the fuel system may do this too.
Old 08-30-2009, 03:36 PM   #14
reminds me of how my FB is acting only it will start and run just dandy. Just hates "driving"
Old 08-30-2009, 07:14 PM   #15
jerd_hambone
It may be flooding, it does run rather rich, but it only does it sometimes, and it has no problems hot or cold starting.
Just has alot of problems driving at completely random points in time
1986 Luxury Package
1988 SE (sold)
1989 GTU (sold)
1990 GTU (sold)
