Old 07-31-2009, 01:37 PM   #1
jimmys79rx
jimmys79rx is on a distinguished road
holley probs on 13b
when i take a right handed turn it feels like i lose fuel for a split second, any sugg.
jimmys79rx is offline   Reply With Quote
Old 07-31-2009, 04:09 PM   #2
Rogue_Wulff
Non Member
That is a rather common problem with any carb.
You could have fuel slosh in either float bowl that is actually flooding the carb for a second or two. I'd try lowering the float level in the rear bowl, and see if that helps. It may take a bit of trial and error before finding the best setting.
Another old holley trick, is using a short length of fuel line attached to both bowl vents, and a cutout in the middle, pointed upwards. When fuel sloshes in the float bowls, it tends to splash out of the vent, and into the throat of the carb. This helps prevent fuel from getting into the throat of the carb. There's only one way to stop the slosh, slow down before turning...... Not fun.
Old 07-31-2009, 10:51 PM   #3
PercentSevenC
Custom User Title
PercentSevenC's Avatar
Originally Posted by Rogue_Wulff View Post
That is a rather common problem with any 4-barrel carb.
Fixed that for you.
When I had my Holley (and my Edelbrock was the same way), I'd experience a stumble on left-hand turns, suggesting that the fuel was sloshing away from the primary jets. It would also stall if I stopped too hard, especially when going downhill. My eventual fix was to swap my Weber 45 DCOE back on. No regrets there.
Old 07-31-2009, 11:57 PM   #4
Rogue_Wulff
Non Member
Sorry, but all carbs that have floats, float bowls, and fuel, will have fuel slosh.
Not all carbs are prone to having the fuel sloshing to a point that it actually causes a *noticable* problem, but they all have the sloshing, unless used on a totally stationary device.
Liquid simply doesn't sit still when the container it's in is moving around.
Old 08-01-2009, 01:35 PM   #5
PercentSevenC
Custom User Title
Obviously, but that's not what I said. The problems the OP is describing just don't happen with Webers or Weber-derived 2-barrels.
jimmys79rx: Another thing to try is lowering your fuel pressure. If that doesn't help, this might:
http://www.holley.com/26-89.asp
Also, which floats do you have? Center-pivot or side-pivot?
Old 08-12-2009, 03:37 PM   #6
RX-7 Chris
RX-7 Chris's Avatar
This is a great trick. We used to do this all the time for 4-wheeling because we'd have the same problem when at steep angles.
This does happen to all carbs but some easier than others.
