Old 07-09-2009, 11:27 PM   #1
boost d3vil
boost d3vil is on a distinguished road
Polishing question
I have a few questions about polishing some of my engine parts to include the IMs, throttle body, IC pipes, ect.
What are some good tools to use for the sanding part instead of the usual wet/dry sandpaper and elbow grease. I've read to use die grinders but not sure if my air compressor is big enough to run one. They use a lot of air from what I've seen. How about electric die grinders are they worth it?
Also I have a bench grinder w/ the buffing wheels I will be using with the metal polish but is there some type of sanding wheel I could put on there?
Just trying to shorten the amount of time it takes to go through the sanding stages.
Thanks for any tips.
boost d3vil is offline   Reply With Quote
Old 07-10-2009, 12:29 AM   #2
rotorhead87
Rotors > Pistons
rotorhead87's Avatar
Hate to break it to ya, but the majority of sanding is gonna be based on elbow grease. What I did to all my aluminum parts was started off lightly with a 60 grit just to knock down all the rough casting and eventually work my way up to the finer grits. I used a black&decker mouse hand sander and a dremel tool w/ the extension for every opportunity I could use them. I generally stayed away from stronger tools for polishing because theres a good possibility for creating flat spots or gashing the aluminum. Overall its just going to take a bit of time and patience, but it'll come out really nice if done right.
***UPDATED 06/15/2009***
Old 07-10-2009, 09:56 AM   #3
boost d3vil
Yeah I hear ya. I'll just work up through the grits then and use a dremel or something when I can.
Old 07-10-2009, 12:13 PM   #4
Project10AE
Project10AE is on a distinguished road
I just use power tools (die grinder, dremel, etc) to get off stuff like casting marks, seams, etc... after that I usually hit it with the blast cabinet to knock down and even out the finish... after that its all about the elbow grease until its time to actually polish.
Hence why I have started just smoothing out parts and having them powdercoated... SOOO much easier than trying to get a perfect polish finish and none of the maintenance of having to re-polish / clean spots off of polished things.
Project10AE is offline   Reply With Quote
Old 07-10-2009, 03:16 PM   #5
Agreed - I use to hand polish things all the time, but learned that getting them prepped for polishing and then just powdercoating them turns out really well...
Actually, I once powdercoated some polished parts, that was a PERFECT finish..
Old 07-10-2009, 09:42 PM   #6
Garfinkles Motor Works
I use both air and electric die grinders .I think the electric one comes in handy alot of the time .Well worth the money for me .Let me think ,have I ever polished any parts ?
Old 07-11-2009, 12:49 PM   #7
boost d3vil
What type of sanding accessories are best for the die grinders? I can only find like small 2 inch discs at the local home depot and they only go to 120 grit I believe. Where as the dremel has all sorts of sanding accessories that go up to 320 I believe and their small for hard to reach spots.
Old 07-11-2009, 08:50 PM   #8
Project10AE
I had to go to autozone / northern tools to find some of the 3m sanding discs and the adapter they come with to fit into a rotary tool...
Old 07-14-2009, 01:49 PM   #9
boost d3vil
Here are some pics of my first attempt at polishing. I've sanded from 320 all the way through 1500 and used about 2-3 ounces of my 4 ounce tube of tripoly. I'm going back over with white rouge but isn't it suppose to be really shiney even after tripoly. I must have done something wrong?
Here's my dirty wheel lol
Old 07-14-2009, 04:14 PM   #10
Project10AE
Dosen't really seem like you spent enough time working up through the sanding phase from the pics...
Old 07-14-2009, 04:34 PM   #11
boost d3vil
so I need to go back over it and sand some more
Old 07-14-2009, 04:45 PM   #12
Project10AE
it should all be a smooth matte finish on its own before you even have to polish. all those spots where you see dark spots (that arent a shadow) are where it isn't evenly sanded.
I'd start around 800grit and sand until you have a uniform finish... then go up from there. when i get over 1000 i usually just skip 1500 and all that and just wetsand it with 1000+ until it is all uniform. Its not so much about the 'polishing' as it is about the 'smoothing'...
Old 07-14-2009, 05:16 PM   #13
boost d3vil
ok cool thanks for the advice I'll try again.
Old 07-14-2009, 05:58 PM   #14
FDSeoul
it's smoking
FDSeoul's Avatar
FDSeoul is on a distinguished road
I have found that using a dremel with various bit heads to removed the cast lines and then a series of sandpaper has given me the best results
here are some pictures.
if it's smoking then it's working
FDSeoul is offline   Reply With Quote
Old 07-14-2009, 06:06 PM   #15
FDSeoul
it's smoking
FDSeoul's Avatar
here is a picture of a cross pipe after 150grit
after 1500 grit wet sanding and hand polish
recent e-bay picture
