Old 06-09-2009, 04:06 PM   #16
87 t-66
87 t-66's Avatar
87 t-66 is on a distinguished road
the pass window will not budge with the driver side switch...
with the pass side switch it will go down fine but only go up half way and its VERY SLOW
87 T2
90 T2 'Vert
87 t-66 is offline   Reply With Quote
Old 06-09-2009, 07:38 PM   #17
Rx-7fetish
Blue Blur
Rx-7fetish's Avatar
I have close to the same problem only the passenger side wont work for either switch now, it was working fine, i rolled the window up and that was it, it wont budge up or down now. Wont even try to move
Old 06-09-2009, 08:41 PM   #18
1) Clean power window motor (they almost NEVER fail)
2) Use graphite lube on all the friction surfaces.
3) Make sure you are not plugging the door light plug into the window motor ( ask me how I know )
If all else fails, clean and re-clean the drivers side switch.
Old 06-10-2009, 09:06 AM   #19
87 t-66
87 t-66's Avatar
what would be good to clean it with?
87 T2
90 T2 'Vert
Old 06-10-2009, 09:19 AM   #20
For the switches, take them out of the door panel, remove the 2 screws on the bottom. There are 2 little metal v-ish shaped contacts that rock back and forth. Luckily they are keyed so they only go in one way. I use a little fine sandpaper to clean them with some rubbing alcohol.
Has worked for me everytime!
Old 06-10-2009, 09:29 PM   #21
87 t-66
87 t-66's Avatar
what about the motors themselves?
i also heard the s4 switches are rebuildable...is there a write up on this anywhere?
87 T2
90 T2 'Vert
Old 06-11-2009, 01:16 AM   #22
Rx-7fetish
Blue Blur
Rx-7fetish's Avatar
Thats how you rebuild them, just did that in my tenth ann. The previous owner told me the motor was bad and some wiring was screwed. Works fine now after cleaning the switch.
!!! Theres 3 screws, 1 on either end and 1 in the middle. Just caught that. But other than that hes exactly right. Also clean the v shaped pieces and the contacts that they touch, and dont forget if its the drivers side to do the same with the part that controls power to the passenger side switch
Old 06-11-2009, 07:29 AM   #23
My contacts were worn beyond repair. I'm in the process (granted it's taken me over a year so far) of making my own switches with some modular rocker switches. I have to actually find the rockers I like then some plexiglass to install them into, but I've gotten both driver and passenger sides to work using some temporary rockers that are a little too big for my tastes.
Old 06-19-2009, 11:42 PM   #24
Rx-7fetish
Blue Blur
Rx-7fetish's Avatar
pics?
