				Rep Power: 19 ![]()  |
				FD fuel rails on the S5 motor?
			Has anyone put fd rails on an s5 motor?
			Would it work or would I have to run the FD upper and lower?
	I own A few Rotaries and Yes, I have a rotary problem. (SELLING OFF All my parts) 79SA(Respeed Car),93 FD (tweakit)  |
			 Rotorhead
				Rep Power: 18 ![]()  |
			The I know the secondary injectors are not in the same place, I've seen a S5 fuel rail mounted to an FD and it had to be lengthened considerably.
	![]() ||| Never argue with idiots. They will bring you down to their level and beat you with experience. |||  |
			so if I run the fd intakes then that would not be a problem.
				Rep Power: 22 ![]()  |
			Just get a KG Parts fuel system.
			You can run an FD upper with a spacer/adapter from the S5 LIM to the FD UIM. You can't run the FD LIM. So it isn't as simple as just swapping intakes. What are you trying to build Chad?
	1976 Mazda Cosmo RX-5 1976 Mazda Cosmo RX-5 2003 Toyota Tundra TRD 2015 Toyota 4Runner SR5  |
		#5 | |
 Maybe I should just go carb'ed.... Check you pm's DJ.
