Old 05-03-2009, 11:42 PM   #1
yamzz
yamzz is on a distinguished road
"bouncing" idle problem
So I have an 87 N/A FC. Two days ago i finished installing a new clutch. and of course in the excitement, i decided to take it out to get gas and some much needed air for the tires.
a little over 15 minutes of driving the engine had warmed up, and started acting up. The first sign of trouble hit when i came to a stop sign. the car started dropping below regular idle, then would recover by over shooting regular idle.
by the time i left the gas station it got worse. as i would come brake for the light and put it into neutral, the car's idle would drop, bounce back up, drop then die.
the idle problem has happened before i swapped clutches, but it's never died.
can someone help me out here?
yamzz is offline   Reply With Quote
Old 05-04-2009, 08:02 AM   #2
My5ABaby
My5ABaby's Avatar
Have you checked for vacuum leaks?
Also, unplug the BAC and see what happens.
Community Service Manual
RotorWiki
Old 05-04-2009, 09:35 AM   #3
Rx-7fetish
Blue Blur
Rx-7fetish's Avatar
So just to check here, the tps only acts up like that before the car is warmed up usually right?
Old 05-04-2009, 11:42 AM   #4
set the tps when the car is warm. go for drive, come back and immediately set the tps. repeat if necessary.
