Old 04-15-2009, 12:57 AM   #16
Originally Posted by $100T2 View Post
So if I'm missing the actuators, unless the aux ports are wired open, I'm going to be missing some high end power, yes?
It looks likes they're in the closed position from the look of the rods. I would suggest checking to see if they just ended up removing the sleeves. I think you'd be able to tell if they did or not by driving it; do you have to rev the engine before engaging the clutch to move up a hill or on flat ground? If so you may have the sleeves removed. If you're not sure, check. only a few nuts and bolts to undo and look at.
Old 04-15-2009, 08:26 AM   #17
Originally Posted by RotaryResurrection View Post
s5 6 port actuators do not work on s4 LIM's...they turn differently than s4. Plus the air gets delivered differently.
Aww, oh well, in that case I will just throw them in the garbage or something... if anyone needs a FREE set of actuators tell me before it's too late guys.
Old 04-15-2009, 07:22 PM   #18
SecondGenPat
Start a Revolution
SecondGenPat's Avatar
SecondGenPat is on a distinguished road
Also, I've never had faith in the headers and silencers that claim to be able to run the 6 ports. There will be little backpressure without an actual cat, and 4-5psi is necessary to operate the ports. You're far better off to just rig something up using the air pump or an electric air pump IMO.
I have always questioned that as well.
One idea I had was to pinch the SAP somewhere along the way to the resonator to act as a restrictor. I would not pinch it all of the way, just enough to provide the proper resistance. Any thought as to why this would be a bad idea?
That to secure these rights, Governments are instituted among Men, deriving their just powers from the consent of the governed, — That whenever any Form of Government becomes destructive of these ends, it is the Right of the People to alter or to abolish it, and to institute new Government
-The United Stated Declaration of Independence
SecondGenPat is offline   Reply With Quote
Old 04-19-2009, 07:05 AM   #19
NoDOHC
NoDOHC's Avatar
Generating pressure from the pump. I tried it with limited success (used a plate with a very small hole in it what the line bolts to the cat). The pump is not always intelligent about when it pumps air into the exhaust. I had to do something to the ACV as well (I don't remember what it was - too long ago).
I did get it to work pretty well in the end, but I had to put a helper spring on the actuator in order to get it to open at 3500 rpm.
Old 04-19-2009, 10:25 AM   #20
$100T2
Big Daddy
$100T2's Avatar
I looked at the other side of the engine, and there is a block off plate where the other actuator would go. I'm assuming the sleeves have been removed.
