Old 04-16-2009, 05:35 PM   #16
Default
keep us posted.
Old 04-16-2009, 06:07 PM   #17
NOLA RX-7
NOLA RX-7 is on a distinguished road
Default
Originally Posted by Phoenix7 View Post
keep us posted.
any ideas??????????? I did the engine code What is this, 1 long light.
NOLA RX-7 is offline   Reply With Quote
Old 04-16-2009, 06:20 PM   #18
Default
retest TPS, check AFM, check leading spark (coil, main relay, plugs, wires), recheck for vac leaks...pretty much everything everyone has recommended.
I gave you links to info on HOW to make your own code tester to pull the codes and further pinpoint the issue....the links also includes a short list of codes, and how to tune your TPS. That same thread has a link to the FSM which explains how to test the AFM, the coils (although I've never wanted to test the coils like the FSM says due to fear of getting electrecuted)....
The best tip is start with a compression check THEN test the TPS.
Old 04-16-2009, 06:43 PM   #19
NOLA RX-7
Default
ok i will do thad...Tk
Old 04-17-2009, 04:19 PM   #20
NOLA RX-7
Default
my plug have the GL,ABR and DCC1 .nothing else.
Old 04-17-2009, 04:50 PM   #21
Default
You have an S4?
Old 04-17-2009, 04:55 PM   #22
NOLA RX-7
Default
You have an S4?
s5 1990
Old 04-17-2009, 04:59 PM   #23
Default
I'm at work so I can't look anything up, I'll try when I get home....you're saying that your TPS only has 3 of the 4 prongs to test it?
Old 04-17-2009, 05:01 PM   #24
NOLA RX-7
Default
no the one nex to the coil for ecu call me if you can michael
Old 04-17-2009, 05:05 PM   #25
Default
don't put your number out in public like that....too much hassle from spammers and crap.
Edited
Old 04-17-2009, 05:08 PM   #26
NOLA RX-7
Default
I'm sorry dood, I don't understand...You're talking about the green prong for the ECU code tester?
the one by the L cooil pack
Old 04-17-2009, 05:11 PM   #27
Default
You're missing the DCC2??
Old 04-17-2009, 05:13 PM   #28
NOLA RX-7
Default
yep
What can i do?
Old 04-17-2009, 05:18 PM   #29
Default
ummmmmmm........is the wire still attached where DCC2 should be? Are you sure you're holding it right side up? (don't mean to insult, just making sure we're both looking at the same part in the same manner).
If you can then splice into the wire and plug in DCC1 and ABR the regular way.....got a pic? Also, I don't think I'd be much help on the phone since we'd still be on the same boat trying to figure out what's wrong.
Old 04-17-2009, 05:22 PM   #30
NOLA RX-7
Default
No no cable is just a empty spot
Ad Management by RedTyger
