Big Daddy
What a difference the right presilencer makes...
Yo, yo, check out the old mAd TytE catalytic the previous owner put on!
Yep, it's totally hollow. And I was wondering why I couldn't hear myself think at anything over 2000 rpm.
Hell hath no fury like a rotor blown. |
Big Daddy
What else is wrong? Hmm. There's no connection back to the engine for the 5th and 6th ports. Mad bolt welding skillz, yo!
If anyone can tell me what that open vacuum line is, I'd appreciate it. Also notice where the pickup for the aux ports is is wide open. I'm assuming they are wired open, but I can't tell, and don't even know where to look. Guess what else? The O2 sensor wire is busted. Could that be why the car gasses me out every time I try to drive it?
Big Daddy
And here's the correct RB presilencer. The car is a good 9 million dB quieter now. I gotta get the tube from there to the engine, and see what the deal is with the rest of this. I'm also going to replace the O2 sensor with a brand new one I have laying around, and replace the entire shitty, spliced wire you see in the picture. Hopefully it will have the 'vert running much, much better, and stinking much, much less.
Big Daddy
The metal thing sticking out right where the black and red wires are spliced together. It looks like it needs a hose on it, but I don't know what for.
Rep Power: 20 ![]() |
doesn't need to be connected to anything. just vents excess air from the airpump. Just use the air pump for actuation.
Big Daddy
Are my 6 ports wired open? How can I tell?
I have no airpump, btw. The only thing still on the motor is the power steering. No A/C, no airpump. I need A/C. Stat. Summer here is a bastard.
Out of Nickels and Dimes
doesn't look like it... looks like the actuators are just missing. I can try to snap you a pic of mine when I get home later.
1988 GXL |
#8 | ||
Since he's installed a resonator and header combo, the SAP has pretty much become useless so wouldn't that hose then just become a vent from the Air Pump and ACV?
The Official FC Radiator Thread My Project Thread: Cerberus CCVT Virginia Rotary Group Last edited by vex; 04-14-2009 at 07:59 PM. |
#9 |
Big Daddy
So if I'm missing the actuators, unless the aux ports are wired open, I'm going to be missing some high end power, yes?
#10 |
See attached pic... best I could manage in the dark. You can see that the little vacuum line runs to the split air pipe under the check valve. You can also see the Air control valve and one of the port actuators that you're missing. And yes, if you're missing the actuators and the ports are not wired open, you are losing top end, conversely, if they are wired open... you lose a little low end. That's why they exist
![]() *Nevermind the green twist tie mod, I can't disclose the horse power gains per my mechanics wishes ![]()
1988 GXL Last edited by RoughRex; 04-14-2009 at 09:25 PM. |
#11 |
I have two S5 Actuators, as well as an S5 split air pipe if you want them, free, just pay shipping if you want to try em out. I can cut the split air pipe so that it fits into a smaller box too.
#12 |
Big Daddy
Excellent. Paypal info?
#13 |
pm'd!
#14 |
My car is an S5, and the LIM had the actuator rods SEIZED in it, so the 6Port crap was useless now. I ended up removing all emissions, 6pt, VDI actuator (safety wired open, lol) cat, airpump, and some other stuff as well.
Ironically I did NOT do the TB mod, messed up one TB doing that already.
#15 |
This is an S5?... Why was I under the impression this was an S4? I'm so confused now.
Bookmarks |
Thread Tools | |
Display Modes | |
