Old 03-20-2009, 07:08 AM   #76
The thanks you's and shout outs come when the project is finished!!
And Low Imp, you're right. Paul (Fero313) just picked up a 91 vert, and its VIN is FC35
Old 03-20-2009, 03:02 PM   #77
yup! Bobby, I was going to do a "thank you" shout out when the car gets painted, and stage 1 of the project is finally done.
however, I do humbly thank Bobby, aka "Nopis1O" for being a friend, helping me with the car, and giving me some parts I really needed to finish the project!
Old 03-29-2009, 01:28 PM   #78
Ok, so I just finished up my door panels. I bought some new foam, some suede cloth, and some thin yarn cloth (almost exact match to factory) to redo the speaker "vents".
My door panels were originally blue leather ones, and were pretty nasty. I took them apart, scrubbed all the vynil/plastic areas clean, and coated them with Duplicolor flat black vynil dye, which turned out amazing. I also put the little carpet areas through the washing machine, and dyed them black as well. This has been one of the most "fun" things I've done so far, and for what I spent I am VERY happy with the results!
Total budget for this:
$10 for 3M general trim adhesive
$5 (x2) for a can of Duplicolor vynil dye.
$12 for suede, foam, and speaker cloth
Having fresh door panels that look like they just came from Mazda: priceless!
I will post pics up in a little bit.
Pictures:
On the car:
Old 03-29-2009, 06:16 PM   #79
Pics are up. /\
Old 03-30-2009, 12:35 AM   #80
Nopis1O
Nopis1O's Avatar
Nopis1O is on a distinguished road
looks good. might wana die the edges a little more but overall its a good turnout
1988 Fc Vert. Super Stock
1990 Fc Hard top: Brideported 13b, weber carb, 350z wheels w/nitrogen, or 16in BBS meshies, Msd, Racaro Racing Seats, Custom Gauge cluster, custom Intake, Relocated Battery, 3inch header back borla exhaust system, Alpine stereo system, Wire tucked, S4 shift boot&knob, custom Strut bar, And soon to come a Full black w/ gold pearl paint job, powder coated break calipers, all black interior, bride headliner/door panels.
Nopis1O is offline   Reply With Quote
Old 03-31-2009, 08:50 PM   #81
Remembered about some rust while putting the driver's side door panel back on. In order to properly fix the rust spot, I had to pull off the door and front fender. Since this is a bitch to do, I neglected the repair untill now, and almost forgot about it. Taking the door off by myself was a PITA btw, you WILL hurt yourself, and probably break the door if you try, I just got really lucky cause I dropped it on grass.
This is a pic of it half finished, i took ALL the rust off before I coated the frame with paint, just forgot to take a picture of it, lol.
Primered:
Painted and clearcoated:
Old 03-31-2009, 09:34 PM   #82
That black on blue would annoy the crap out of me. Good job getting rid of the rust though. What'd you use for primer?
Old 03-31-2009, 11:41 PM   #83
I used Sherwin-Williams rust preventive primer, my friend who works at the comany (Nopis1O) told me that you can pretty much spray this over rust if you wanted to.
As far as the looks, I'm going to do the door jams in black, while the rest of the car will be white. also, this chassis is not that perfect shape either, and the FC is my "learners" car so i really dont mind if it's not "perfect".
Old 03-31-2009, 11:43 PM   #84
rust is the devil
Old 04-01-2009, 12:03 AM   #85
need RX7
Clean S4 Nutswinger
need RX7's Avatar
Originally Posted by Low Impedance View Post
rust is the devil
Yes it is :9 898:
Old 04-08-2009, 05:50 PM   #86
Ok, so I just ordered the Oil Cooler lines from Mazdatrix, used 2day-air shipping, so they should hopefully get here friday.
I also got a Palm VII pda for $25 shipped, and a hotsync cable for it from here: garka.com for half of what it costs elsewhere.
Also bolted down the hood finally! Havent had the hood on the car since I took it off over a year ago, It took me a sec to get the hood to fit right, and line up the front end halfway decent, but I got it at least somewhat respectable.
At this point, I will bolt on the lines, hook up the PDA and setup the RTEK, after which, with a boatload of luck, this thing should fire again!
If everything is fine and dandy at this stage, I will get the car insured, registred, and take care of the floor, then put the carpet in, and it will be all set for the trip! This is gonna be good!
I tried my best to eliminate any vac leaks possible, as well as do everything else right (got new seconday injector connectors because stock were broke). anyway, we will see how this goes!
Old 07-26-2009, 03:58 AM   #87
UPDATE:
So, I didn't make it. I got the car on the road now, but I've been plauged by mis-adjusted set screws on TWO sets of throttle bodies now. I purchased another one, and my car still ran like shit, so I suspect that my issue has something to do with all the adjustments....
In other news, I got some work done on the interior...
I finally found out that you can get dry ice at the blood bank, (which I didn't know before, and no one else sells it in Champaign) and went to work on the rest of the sound deadening crap in my car. I also cut out the annoying spare tire brace that was useless and taking up valuable space.
I still need to weld the floor, clean up some rust, spray bed liner, and install fresh carpet (power washed and dyed black) so shit aint finished yet, but it will be soon.)
I've also been thinking of foaming the rocker panels, but the foam shit is so expensive...
Oh yeah, and I also got some lowering springs...
Here's some pics:
Here's the car lowered from it's 4x4 stance:
Old 09-01-2009, 02:23 PM   #88
Well, I've been thinking about stuff, and I might end up doing a turbo swap. If I go through with this, I will have a number of good items to sell off, some of which are:
2.0 S5 N/A RTEK with PDA and Sync Cable. $250
Racing Beat Street Header $120
S5 N/A Injectors $100 (Cleaned and flow tested by Witch Hunter, cost me $80)
S5 Rotor housings and irons
S5 N/A Transmission $50
S5 N/A Starter $30
S5 N/A MAP Sensor (2x) $15 each
S5 N/A AFM $20
S5 N/A Stock ECU $50
If you see this, and there is anything you need, please send me a Private Message or post a reply here.
Old 09-01-2009, 03:11 PM   #89
Make a decision man. You need to make it to DGRR '10. A turbo swap is insanely easy, just get everything before starting. You can save some time and money by keeping the N/A trans for now. (been using mine for almost 5 years)
That way you won't need to sell/buy:
-starter
-transmission
-driveshaft
Old 09-01-2009, 03:17 PM   #90
I thought of that, but the N/A trans wont hold up to drifting abuse... =(
