Old 03-31-2009, 07:25 PM   #16
http://picasaweb.google.com/lh/photo...eat=directlink
Old 03-31-2009, 07:26 PM   #17
someone can take that and color it if they want
Old 03-31-2009, 07:27 PM   #18
Yes, where the TB mounts to the UIM. There should be 3 or 4 ports on the side that faces the firewall. One is larger than the others, and that feed the oil injectors.
(pic courtesy of Rotary Resurrection)
The others cap off. Your injector regulator source is on the UIM in the middle of the injector bleed ports:
If you need more guidance, go here--> http://www.rotaryresurrection.com/2n...s_removal.html
Old 03-31-2009, 07:32 PM   #19
NOLA RX-7
NOLA RX-7 is on a distinguished road
what about the other 3 lines on the other side
NOLA RX-7 is offline   Reply With Quote
Old 03-31-2009, 07:35 PM   #20
Cap them all.
Old 03-31-2009, 07:41 PM   #21
NOLA RX-7
cap all of them? the other 3 on the other side?
Old 03-31-2009, 07:44 PM   #22
Yes, on the TB, you will only have the one vacuum line used for the oil injectors, all others get capped.
Hint-use GOOD caps. The heat destroys cheap rubber caps. You will be changing them every year.
Old 03-31-2009, 07:55 PM   #23
NOLA RX-7
all ready done now the hose from intake
Old 03-31-2009, 07:57 PM   #24
What hose from the intake?
Old 03-31-2009, 08:03 PM   #25
NOLA RX-7
this one
Old 03-31-2009, 08:14 PM   #26
Where is it/was it going to and coming from?
If it went to the air pump, you don't need it. If it goes to the ACV, you don't need it. If it went to the stock BOV, you don't need it.
Air filter->AFM->turbo
Thats it.
Old 03-31-2009, 08:20 PM   #27
NOLA RX-7
ok got it. i have one more pic and ?...
Old 03-31-2009, 08:24 PM   #28
NOLA RX-7
1 of this lines is sucking air cap it to
Old 03-31-2009, 08:27 PM   #29
If it is sucking air, it is a major leak.
Cap it.
Old 03-31-2009, 08:29 PM   #30
NOLA RX-7
this one
