Old 03-01-2009, 11:47 PM   #1
NoDOHC
NoDOHC's Avatar
Polishing Rotors - Pros and Cons
Right now I am in the act of freshening up an 88 4-port engine for in my '86.
I have seen many people polish the rotors before installing them, I decided to do the same.
The reasoning that I used is that it will decrease carbon buildup, improve heat rejection of the rotor and decrease exposed surface area which should minimize fuel precipitation and improve knock resistance.
My question here is whether the rotor requires some irregularities for improved turbulance as the air exchanges past the point between the leading and trailing plugs (right before it ignites the charge). Will polishing the rotor sacrifice startability and low-end toque by eliminating an important fuel mixing mechanism?
Maybe this question has yet to be researched. I only brought it up because I can't decide myself if it will improve flow or harm it.
I went ahead and polished the rotors, so I can only hope there are no negative side effects.
Old 03-01-2009, 11:48 PM   #2
it theoretically should help keep carbon build up down for sure, which can keep hot spots from forming on the rotor.
Old 03-02-2009, 12:47 AM   #3
They come coated from the factory.
Polishing them just just got rid of that special coating.
I don't bother, except to knock off all the crud.
No on see them once the motor is assembled anyways.
Old 03-02-2009, 06:53 PM   #4
NoDOHC
NoDOHC's Avatar
I wouldn't have polished them if I knew that they were coated, they looked like rusted metal to me.
I hope I don't regret that.
Old 03-03-2009, 08:04 AM   #5
N.RotaryTech
Home-brew Rotary
N.RotaryTech's Avatar
Do you have pictures?
Old 03-03-2009, 08:50 AM   #6
To_Slow
Here some pics i did for a 3 rotor custo couple off years back...
Regarding benefits by polishing the rotors, it will help with carbon build up control in theory . How much i really do not know. That 3 rotor i did for that custo is not do for a rebuild yet. I will also be interested to se how much it helped with the carbon control or if any at all. From looking at the first pic you can se how much carbon the rotor had on it...
My link
Old 03-03-2009, 12:52 PM   #7
isnt there some kind of coating you can get on the rotors too now a days?
Old 03-03-2009, 02:23 PM   #8
My5ABaby
My5ABaby's Avatar
Cermet.
Community Service Manual
RotorWiki
Old 03-04-2009, 01:19 AM   #9
charlies7
one broke moderator
charlies7's Avatar
charlies7 is on a distinguished road
Swaintech also provides a high temp coating for rotors..Ceramic based.
Originally Posted by My5ABaby View Post
Cermet.
charlies7 is offline   Reply With Quote
Old 03-04-2009, 01:21 AM   #10
ah there we go! what company does the service?
Old 03-05-2009, 05:08 PM   #11
Atkins Dan
Premium Vendor
Atkins Dan's Avatar
Atkins Dan is on a distinguished road
This coating from the factory is just a anodize usually gold or green in color..
So depending on how harsh {or strong} the chemical you use to clean the rotors with, it will take it off anyway..
Dan
82 SuperCharged rx-7 {my toy not the daily driver anymore now under restoration}
88 B2200 rotary powered with a 7inch Camden SuperCharger !RIP! Jan/4/2007
2001 626 5-speed 80k on the clock all stock {Truck replacement}
2005 MAZDA6 V6 WAGON now that is a pimping ride all stock for the moment.. Paid off
WWW.AtkinsRotary.com
Atkins Dan is offline   Reply With Quote
Old 03-05-2009, 10:52 PM   #12
I've never seen anodizing appear like that.
I've never heard of any anodizing internal engine parts.
I've never heard of anyone anodizing steel / iron - only aluminum?
I don't think the rotors are aluminum.
Cadmiun perhaps?
SAE papers claims it's a special coating for oil adhesion.
It's on the rotors faces + on the outside edges of the rotor from the side seal groove to the edge of the rotor faces.
Old 03-05-2009, 11:42 PM   #13
Atkins Dan
Premium Vendor
Atkins Dan's Avatar
Sorry Ted I ment cadmium plating on the rotor... On the other coating there is a small amount of teflon {I think} on the outside edge of the side seal on the rotor its self...
For a coating on tub side of the rotor it may be there but i have never seen it on brand new rotors {Rx7 or 8}
If you don't mind can you post a link or scan the SAE papers you are reading???
Dan
Old 03-15-2009, 10:47 PM   #14
NoDOHC
NoDOHC's Avatar
A few questions:
What would you call this? (Street port? Stock port?)
The intention was to avoid changing port timing while providing a nearly consistent cross-sectional area for the primary and secondary runners and ports. I am not sure if this is still a stock port due to stock port timing or if it is considered a street port.
Here is a picture of the finished rotors (I would post more, but it is too much work resizing them).
Old 03-16-2009, 09:05 AM   #15
Atkins Dan
Premium Vendor
Atkins Dan's Avatar
in my mind that is a street port..
as for the rotors good job and it looks good too..
Dan
