Go Back   Rotary Car Club > Vendors and Group Buys > All Vendors > Densetsu Motorsports LLC
Densetsu Motorsports LLC www.dm-spec.com (AZ) High quality aftermarket performance parts and installation
Old 01-09-2009, 05:14 PM   #1
Flooder
Flooder's Avatar
Flooder is on a distinguished road
Ksport Kontrol Pro coilover sale
This is for the FC only. If we sell 5 sets of these I can get them to you for $700 shipped. I've got this posted on a few different forums so it'll probably be pretty easy to get 5 of these sold.
Ksport Kontrol Pro coilovers.
AZRX7.COM
Red 1991 A-package(SOLD)
Red 1990 GXL(SOLD)
White 1989 GTUs(DEAD)
Red 1988 Turbo II(DD)
Black 1988 Turbo II(SOLD)
Rebuilt and street ported motor, Garrett T04E Turbo, 3" Turbo Inlet Duct/AEM Dry Flow Filter, Your Mom's MBC, Blitz FMIC, 890cc and 1000cc injectors, Tomei FPR, Walbro, Rtek 2.1 ECU, Taurus E-Fan, Turbonetics BOV, 3" Motoria/Corksport Turbo Back Exhaust, Emissions Removed, Greddy Boost Gauge, Megan Racing Water Temp Gauge, 5one5 Triple Gauge Pod, AEM Uego, GP Sports Body Kit, Fiber Images CF Hood, S5 Seats, S5 Tails, S5 Alt, Dual Alt Pulley, D2 Coilovers, NRG Quick Release, Shook Motorsports Radiator, HID's, AN/Steel Braided Oil Cooler Lines, SUPER JDM TYTE DRIFT BUTTON
www.DensetsuMotorsports.com www.AZRX7.Com www.FloodersAdventure.com
Flooder is offline   Reply With Quote
Old 01-09-2009, 08:43 PM   #2
specs? seems like a really good price for coilovers...
Old 01-10-2009, 12:13 PM   #3
Flooder
Flooder's Avatar
Ksport Kontrol Pro Fully Adjustable Coilover Kits provide the ultimate in suspension technology for your street or track car. 36 levels of dampening adjustment allow you to fine tune the ride to your handling and comfort needs. The dampening adjusts compression and rebound simultaneously for ease of adjustment. Pillow ball top mounts in the front and rear on some applications allow you to maintain vehicle manufacturer suspension geometry design. The pillow ball top mounts also allow you a more direct feel for solid driver response. Camber adjustability is included on pillow ball top mounts that allow it for the ability to adjust camber from the actual coilover, instead of a separate camber kit.
Most applications utilize an adjustable lower mount, which means you adjust height without losing suspension travel like some other coilover designs do. With the mounts and most pieces of the coilover being designed for 6061 billet aluminum the kit is lightweight, durable, and rust resistant. The steel shock body is electroplated with zinc to resist rust and the elements. The valving of each set is matched to the springs installed for unmatched ride quality and reliability.
The Ksport system uses a Monotube design in which the oil and gas are separated within the cylinder. When compared to twin tube designs the Monotube dissipates heat better, allows finer dampening adjustments, and requires more expensive design process. Aeration and cavatation are a lot less common in a Monotube design, which results in a better ride.
The Ksport Kontrol Pro Coilover kit has been designed with professional road racing in mind offering extremely high value and performance.
1. 36 levels of adjustable dampening
2. Made from high quality 6061 aluminum with T6 for increased hardness
3. Compression/Rebound adjustable
4. Adjustable spring perch for height adjustment
5. Adjustable body allowing maximum suspension travel
6. Pillowball top mount with adjustable camber (not available for some models)
7. Monotube high pressure design reduces oil leakage
8. Electroplated body for protection from corrosion and rust
9. One year limited warranty
These are pretty decent entry level coilovers. Ive driven multiple cars with them installed and I really like them. If anyone has any more questions, feel free to ask.
AZRX7.COM
Red 1990 GXL(SOLD)
Old 01-10-2009, 12:15 PM   #4
Flooder
Flooder's Avatar
AZRX7.COM
Red 1990 GXL(SOLD)
Old 01-15-2009, 03:15 PM   #5
Flooder
Flooder's Avatar
Sale over.
AZRX7.COM
Red 1990 GXL(SOLD)
