Old 01-01-2009, 09:19 PM   #1
need RX7
Clean S4 Nutswinger
need RX7's Avatar
Slow Cranking, full power to everythiong else
I went out and tried to start my car last night, it cranked very slow. I put it on a charger for about 4 hours, let it sit overnight and tried starting again today. It still cranked slowly today, but I tested the headlights and they pop right up and shine bright. As soon as I try starting it, all the lights dim and the voltmeter needle plunges.
Any ideas what could be wrong. The starter was replaced in February. I'm thinking about the wires running from the battery to the starter, what should I look for when I'm looking at them? Any other ideas?
Old 01-01-2009, 09:44 PM   #2
RotaryProphet
Sounds like the engine ground, or possibly corrosion or loose battery terminals or the starter positive line.
Old 01-01-2009, 10:48 PM   #3
rx7 FC TII
rx7 FC TII's Avatar
im having this problem along with the 3rd gen that i hang out with. i havent started to work on it and figure it out yet but if i figure it out ill report back.
EDIT: ive done a bit more research on this and its sounding like its most likely the starter.check all the connections and grounds for it and if not then you can try to replace the brushes on the starter if you go to napa and order them. ill be doing it this weekend so ill let you know.
http://www.napaonline.com/MasterPage...=Starter+Brush
Old 01-02-2009, 12:09 AM   #4
Sounds like a bad battery...
What is the voltage with everything off?
Ideally it should be over 13.0VDC.
What is the voltage while cranking?
Ideally it should be over 10.0VDC.
The engine can crank down to 9.x VDC, but if it gets any lower than that, the battery is no good.
Old 01-02-2009, 03:06 AM   #5
need RX7
Clean S4 Nutswinger
need RX7's Avatar
It sits right at 12v with the key turned to on and the parking/dash lights on (I couldn't see anything without them ha) I walked away for a couple minutes (with the parking lights on) and it had dropped to about 11v. So I guess I'm off to get a new battery...
I'll still check out the grounds and stuff just in case... Thanks for the help guys.
Old 01-02-2009, 09:33 AM   #6
RotaryProphet
12 volts is normal for a battery on a non-running engine. 13.5 is about where you want the voltage in a running car with the alternator working.
Old 01-02-2009, 11:44 AM   #7
Forget about voltage when the battery is idle (no high amp draw).
Check the voltage with a GOOD METER (no dashboard gauge) when you are cranking the car.
The battery might have a 'dead cell'. They can show a normal voltage when idle, but when load is applied the voltage drops significantly.
I used to be a DC power technician, so I have a clue.
Old 01-02-2009, 02:46 PM   #8
need RX7
Clean S4 Nutswinger
need RX7's Avatar
Alright, the battery's at Murray's right now getting tested. Whether or not the battery is the problem, I think it's about time for a new one anyway. It's not even the right one for the car, it's effing huge. Hopefully I can get an Optima.
Old 01-02-2009, 02:51 PM   #9
dont be so sure about the too huge. The rx7s (FB and FCs) usually speced D28 batteries
Old 01-02-2009, 03:00 PM   #10
need RX7
Clean S4 Nutswinger
need RX7's Avatar
Yeah, I know the battery's supposed to be pretty big, but this one doesn't even fit right in the battery tray (and the PO told me it came from a truck )
Old 01-02-2009, 03:59 PM   #11
Fidelity101
Reliable Source
Fidelity101's Avatar
optima red/yellow top are good batteries but pretty damn heavy and since their solid state if you leave your lights on or something overnight and you drain your battery, tough luck you need another one.
My Rx-7 Vids
Old 01-02-2009, 04:27 PM   #12
Not solid state, Absorbed Glass Mat.
And yes, once they are toast, they don't come back. I recently had my Red Top go down, form lack of driving. It charged back up, but only lasted another 2 months before it died all together. Now I have the 1000 CCA Red Top in it.
Old 01-02-2009, 04:33 PM   #13
need RX7
Clean S4 Nutswinger
need RX7's Avatar
Alright, the battery I had turned out to be toast, so I picked up a DieHard from Sears. I don't want to drop $150 for an Optima on a car that I probably won't keep for much longer. I haven't hooked it up yet (need to put my trailing coil back on) But I'm pretty confident that the battery will fix the problem.
Old 01-03-2009, 02:03 AM   #14
Fidelity101
Reliable Source
Thats the spirit!
My Rx-7 Vids
Old 01-03-2009, 02:22 AM   #15
rx7 FC TII
rx7 FC TII's Avatar
i wish that was my problem. my starter is fucked. itll barely start so thats my project tomorrow.
congrats on fixin yours.
