Old 11-25-2008, 03:29 PM   #16
rx4ur7
Rotary since 1972
rx4ur7's Avatar
If there is carbon lock(common with motors that have sat) taking plugs out and turning backward can be done. Once you turn it over backwards a couple of times you can usually marvel or any other approved goo and turn in normal direction. If you can get it to turn a few times by hand then turn to starter. If it locks again, try backing it up by hand again. And go through the procedure again. If carbon locked that will usually work. If the motor has 150+K miles could be worn out apex seal lands and worn out bearings.
Please don't use the 6-9 ft breaker bar method, you could break a perfectly good apex seal.
So just turn it with a breaker bar... Should I try turning it backwards first?
Old 11-25-2008, 05:33 PM   #17
Originally Posted by need RX7 View Post
Wow, didn't see that one coming. Any damage to the flywheel?
Has run fine for a few weeks so guess not
