				Rep Power: 21 ![]()  |
				Keeping a hill climb turbo rotary cool
			so i now have a directive. BUT the biggest issue i believe i am going to face is trying to keep the car cool.
			Some important information to get you up to speed:
 So as far as keeping the whole shebang cool. I can see the choice of forced induction really being the major factor. If i run the turbocharger, i will need a larger inter cooler and i believe the oil temperatures will be higher due to the proximity of the exhaust heat plus there will be an impact on the coolant assuming i use a coolant cooled turbo charger. If i run the Camden it is oil cool only, and not exposed as directly to searing exhaust heat. This would also not require an inter cooler and therefore, save a serious amount of space in the engine bay for the radiator and the oil coolers. Everything will have to be carefully placed and ducted for its own protection (first priority) and for optimal flow. I will have to see if i can maybe lay the radiator in a v-mount style and chop the hood to have air directed. Might partially work as a creator of down force as well. OIL: I plan on running two, 18"x14" oil coolers with -10AN lines with fans and a chance of a mister system is things get real bad. The stock oil cooler will not keep up and even the Mazda Comp. Oil Cooler is somewhat lax on doing the job. COOLANT: Will have to run the best radiator i can find and use every trick in the book to improve cooling starting with the build of the engine. Ill have to see how intense the heating system really is to see if a mister will be used here as well.
	For current updates and event coverage check out Follow on Twitter! @WhizbangRally Whizbang Rally's Webpage | Facebook  |
			 crash auto?fix auto
				Rep Power: 18 ![]()  |
			Talk to BLUETII, he hillclimbs his FC.  I believe he's running a Vmount, but don't know about his oil cooler and rad setup
			is he on this forum?
			those with V-Mounts, how well does everything "work" per say?
			 crash auto?fix auto
			ill have to see if i can find him then
		#7 | |
	AZRX7.COM Red 1991 A-package(SOLD) Red 1990 GXL(SOLD) White 1989 GTUs(DEAD) Red 1988 Turbo II(DD) Black 1988 Turbo II(SOLD) Rebuilt and street ported motor, Garrett T04E Turbo, 3" Turbo Inlet Duct/AEM Dry Flow Filter, Your Mom's MBC, Blitz FMIC, 890cc and 1000cc injectors, Tomei FPR, Walbro, Rtek 2.1 ECU, Taurus E-Fan, Turbonetics BOV, 3" Motoria/Corksport Turbo Back Exhaust, Emissions Removed, Greddy Boost Gauge, Megan Racing Water Temp Gauge, 5one5 Triple Gauge Pod, AEM Uego, GP Sports Body Kit, Fiber Images CF Hood, S5 Seats, S5 Tails, S5 Alt, Dual Alt Pulley, D2 Coilovers, NRG Quick Release, Shook Motorsports Radiator, HID's, AN/Steel Braided Oil Cooler Lines, SUPER JDM TYTE DRIFT BUTTON www.DensetsuMotorsports.com www.AZRX7.Com www.FloodersAdventure.com  |
			my "plan" is to run a v-mount like setup since i feel it gives the best attention to the radiator. I will also be running a mister system of some form or another. I have a CO2 based kit with a smaller tank on hand. I might see about using it on the inter cooler with a much larger bottle then perhaps a normal mister onto the radiator.
		#9 |
			 crash auto?fix auto
		#10 |
			 Needing a new tow rig.
			CO huh your not doing pikes peak are you??  v-mount would be best bet but you might look into methanol injection to help keep things cool air-charge wise.  used with your intercooler it will give you subambient charge temps as well as deture detination and cooling down egt temps. as far as a radiator you might look into a custom made one i doubt anything current would allow you to run 9min balls out without help.  try getting in contact with fritts from design engineering works he made a real decent one for the FD i believe the radiator is dual pass 2in core.
			z evans 0 psi coolant is said to be mothers milk for keeping temps in check in a rotary although not cheap Last edited by proz07; 11-19-2008 at 02:46 AM.  |
		#11 |
				Rep Power: 0 ![]()  |
			Intercooler/radiator evaporative water sprayer or a/i.
	I've heard good things about evans, it won't boil at any temperature you'll see but it does have a worse specific heat than any of your water/glycol mixes so you will have a tendency toward higher temps.  |
		#12 |
			that was one partially lucrative idea, running the water sprayer constantly. Also the idea of using a CO2 system was a possibility because it would leave no water on the track but i would have to see what the rate of flow is vs. size of bottle to see if it would last an entire run or not.
		#13 | |
		#14 |
			Hmm...well that might be the best way to go then. The nozzles seem cheap enough and i can build the system from pieces, plumb it how i need, etc.
		#15 |
				Rep Power: 20 ![]()  |
			YOU'RE IN OHIO AGAIN!!!  LOL  Just send the car out to me when you finish it and I'LL take it up the hill, HAHA.
