Old 11-10-2008, 01:43 PM   #31
Jeff20B
Jeff20B's Avatar
Washington, near Seattle.
Old 11-10-2008, 10:05 PM   #32
Ah - figured it was west. Hopefully you can get this fired up before snow...
Old 11-11-2008, 02:55 PM   #33
Jeff20B
Jeff20B's Avatar
Yeah, I need to get this fired up in the next couple days so it can be moved.
Old 11-17-2008, 02:05 PM   #34
Jeff20B
Jeff20B's Avatar
Uhg, it didin't want to fire. The engine is too tight and the starter can't crank it fast enough. I tried all my tricks. The radiator turned out to have a leak also. I tried to solder it but I'll just take it to a rad shop.
I now have a few options. I could try a 6 volt starter with a 12V solenoid (they don't last very long), or get another high torque starter like my current one (doesn't make much sense and is costly).
Plus the choke on the carb isn't hooked up so obviously getting a fresh rebuild started on cold mornings could prove to be difficult until it has some miles under its belt. I also can't rip on it until then. If it snows too soon I won't be able to rev it enough to keep from getting stuck.
A better option is to pull the engine and drop it into the GLC since it needs an engine right now and the engine bay is fully compatible. All the mechanical work is complete in the baja so it's just a few bolts to pull it. It would take no time at all. Couple days, really.
Old 11-17-2008, 02:46 PM   #35
TehMonkay
Try pull starting the bugger to get it running and warm it up.
Old 11-17-2008, 04:39 PM   #36
Jeff20B
Jeff20B's Avatar
I could but I'm not that desperate to get it running with a leaky radiator.
It's not a big deal to pull the engine. Infact this engine was actually in the Cosmo for a while last year for precisely the reasons stated above (to get it broken in etc) but ran out of time and my bro was interested in the Cosmo so I had to put a different engine in it. So I rushed the baja project along and figured I could get away with a fresh rebuild as long as I got it in there and running before the winter. Well, winter is pretty much here now and no runny.
Anyhoo the cut-off point for getting the GLC running is Feb so I have from now till then to come up with an alternative engine for it. Why not use the baja engine in the mean time? That's the part that makes sense to me. So that's most likely what I'm going to do.
I'll get a pic before I pull it in a few days so you can see how the exhaust is routed, wires etc.
Old 11-18-2008, 03:54 PM   #37
Jeff20B
Jeff20B's Avatar
Here it is.
Old 11-18-2008, 04:57 PM   #38
Ah man - it looks so good in there. You can put a different engine in the GLC!!
Old 11-18-2008, 09:34 PM   #39
Jeff20B
Jeff20B's Avatar
The strongest VW starter is unable to start it. I need a loosened up engine. There's one in the white truck...
Old 11-20-2008, 01:08 AM   #40
Jeff20B
Jeff20B's Avatar
I found an old loose 6 port FC S4 engine that I can use in the baja until its tight engine is broken in enough to start quickly and easily.
Old 11-30-2008, 02:21 AM   #41
Jeff20B
Jeff20B's Avatar
I finally made some progress on the baja. I got it back in the garage and had a chance to get started on the FC engine. An auto counterweight is on it and the front 19mm bolt is now snug. It has one of those Atkins aluminum oil pellet things to allow full oil flow to the front rotor bearing at all times. An oil pan and pickup tube are coming up next.
Old 11-30-2008, 02:43 AM   #42
Fidelity101
Reliable Source
Fidelity101's Avatar
Hey I helped your exhaust question on rx7club, didn't know you were on the board. Now I am glad I got to see the build! I love super beetles, I'm kinda a vw/audi guy too, my other ride is a 99 a4 avant.
My Rx-7 Vids
Old 12-02-2008, 02:13 AM   #43
Jeff20B
Jeff20B's Avatar
Cool, yeah you are, kinda.
It turns out the core in the baja's radiator is apparently partially clogged. I pulled it today and gave it a quick rinse. I filled it all the way up with water and let it all drain out. It displayed tell tale signs of a clog. I've seen it before where after you thought all the water was out, you tilt it and some greenish liquid comes out (diluted coolant). You wait a little longer, tilt it and some more greenish liquid. I'll go with a 1st gen rad and mod it where necessary. At least if it gets damaged, I can replace it easily enough. Gotta get creative for how to mounts the fans, though. The core is smaller, leaving less room.
I gotta say I'm feeling relieved that I'm going with a 1st gen rad. I'll mod it in a similar way to the rad in the GLC.
Old 12-03-2008, 09:24 PM   #44
Fidelity101
Reliable Source
1st gen rx7 or 1st gen beetle?
My Rx-7 Vids
Old 12-11-2008, 03:35 PM   #45
Jeff20B
Jeff20B's Avatar
1st gen beetles came out many decades ago and none of them had radiators, so what do you think?
