Old 10-27-2008, 12:30 AM   #1
FortyfiveD
Amudextrious
FortyfiveD is on a distinguished road
Speedo Problem
I'm just curious to see if anyone else has had this problem or if it's just the rearend I have in the car. I'm on my second speedo for my 90 NA and It's already pushing fluid into the back of the dash. Needless to say a few days ago it caused my gauges to die (i.e it blew the fuse in the car). I repaired it and also took the cluster apart to find out that almost the whole circuit board was covered in fluid cleaned it out and put it back together and it works again but I'm not sure for how long.
90 GXL-DD and Track Monster
87 GT-X-Under Construction
FortyfiveD is offline   Reply With Quote
Old 10-27-2008, 10:00 PM   #2
mfisher12
mfisher12's Avatar
mfisher12 is on a distinguished road
what kind of fluid is it?
mfisher12 is offline   Reply With Quote
Old 10-27-2008, 10:18 PM   #3
Einstein
Einstein's Avatar
Einstein is on a distinguished road
I am confused as to what the diff would have to do with your speedo. On my 10AE, at least, the speedo was connected in at the rear of the trans.
My first thought would be - if you have trans fluid getting into the speedo cable and is being pushed into the cluster, then you have a venting problem in the trans. But I need more info.
I have seen similar issues on E38 7series. The coolant temp sensor fails internally and allows coolant to be pumped into the DME (ecu). That's a fun conversation telling a customer that a coolant leak caused them to have to buy a $1500 DME.
Past: 89 RX-7 Turbo II
Past: 88 10th Anniv RX-7 Turbo II
Einstein is offline   Reply With Quote
Old 10-28-2008, 12:32 AM   #4
FC Zach
FC Zach's Avatar
I've had this problem before. Just remove the cable from the gear on the transmission, remove the one 10mm bolt, and find another replacement. Your gear oil is passing through the seal on that gear assembly and traveling through the cable and eventually ending up in your dash. If you cant find a replacement gear PM me, I may have one.
1993 Yamaha GTS1000
1992 Celica Turbo AllTrac
1987 RX7 Sport
1979 Yamaha G1, KM24 powered
1975 Dolmar KMS4
Old 10-28-2008, 12:42 AM   #5
misterstyx69
.drives like MrMagoo!
misterstyx69's Avatar
misterstyx69 is on a distinguished road
ya,there is a small seal on the plastic speedometer gear that goes into your transmission.If it is shot,then you will get Gear oiil into your Dash...as mentioned,get under the driver's side of the transmission,undo teh cable from the Transmission and take the 10mm bolt out,that hold the Speedo gear assembly on.you may have to TAP(hit) it with a hammer,as it sometimes has corrosion around it and sticks to the side of the Trans,But you can just pull it out and get a Replacement for it..OR you can find an O-Ring that will fits on the plastic gear as a replacement seal.Good Luck,STYX.
misterstyx69 is offline   Reply With Quote
Old 10-28-2008, 01:25 AM   #6
FortyfiveD
Amudextrious
Its Transmission Fluid. I replaced all the replaceable part (the speedo cable, O-ring, and gasket/seal) short of pull the trans apart. I don't think it's the trans because this has happen with two different transmissions (doesn't mean it can't happen though) . Also to answer the question about the rearend I have a custom built racing rearend with a 4:88 gearing ratio, so the car stays in the higher RPMs longer.
Old 10-28-2008, 09:16 AM   #7
misterstyx69
try this then,ther is a small tube above the Trans,I think Passenger side.it is for Venting.it looks like,well a Small tube,haha,with a little Cap.this cap is supposed to be Loose an allow venting of the transmission,,see if you can get at it and move,twist the Top little cap(don't pull it off!),If you Can't ,then the trans is building pressure and Putting Gear Oil(transmission Fluid) through to atmosphere,which in your case is the speedo cable.!
Old 10-29-2008, 10:26 AM   #8
FortyfiveD
Amudextrious
Thanks i'll give that a shot
Old 10-29-2008, 11:13 AM   #9
Rotary#10
Rotorhead
Rotary#10's Avatar
wow i never knew that could happen.
Currently running:
90 N/A GTUs..
Running project car
89 N/A GTUs in Black #2
10/6/18
Old 10-30-2008, 05:50 PM   #10
Einstein
Einstein's Avatar
Ha, I was right
