| Rotaryshack www.rotaryshack.com (CA) Specializing in carbs, custom turbo kits, 1gen rx7 parts |
used parts section for sale cheap! check it out
used parts for sale section cheap!!! remember its a buyers market so all prices are negotiable! also if you dont see a part listed you can always request it
![]() -------------------------------------------------------------------------------- i will update this list weekly, so check back often to see if there is anything you want 13B racingbeat exhaust heade--- like new $180.00 used low mileage GSL-SE 13B motor with warranty $500.00 used 12A that runs with oil leak $300.00 used JDM FD 5 speed transmission, does not grind works great $400.00 nikki carb, race prepped $300.00 de-smogged 12A nikki intake manifold(egr and coolant passages have been welded up to reduce intake temperatures) a great power upgrade for cheap! $80.00 black sunroof latch assembly, round dial type( 80-83).......$60.00 exterior door handles fits 79-85 cars.....$25.00 exterior door handles fits 86-92 cars.....$60.00 84-85 power window switches..... $40.00 quiet good condition 79-80 transmission with warranty $350.00 grey 84-85 center armrest assembly, good condition, from a GSL model....$40.00 glass sunroofs avail, 80-85 ppg mfg.. good condition $200.00 new GT47-80 garret turbo.......$2,000 gsl=se afm (used)$40.00 msc engine rotors, housings available, please inquire within(pm) turbo 2 intake manifold inlet adapters(2-1/2 straight inlet)..... $80.00 turbo 2 intake manifolds uppers and lowers available $60.00-$120.00 gsl-se suspension complete changeover includes everything you will need to convert your car ! brakes, rotors have approx. 2,000 miles, front struts were also replaced 4,000 miles ago with original kyb inserts.......$1,500 complete 85 12a non turbo motor.. was running great when removed for a turbo swap.. guaranteed to run good!!!..........$650.00 several msd efi fuel pumps.............$100.00 each msc 91 convertable parts, air bag, turn signal switch, visors,ignition switch fully built pinned bridgeported 13B 4 port( early type) 3mm apex seals new rotor hsgs, all new seals and springs, new oil o-rings and carriers, one year warranty $3,800 os geiken clutch/ flywheel setup, like new twin plate style for turbo 2 $800.00 os geiken clutch flywheel setup, missing pressure plate twin plate style for turbo 2 $300.00
![]() ![]() ![]() rotaryshack.com Last edited by 730RWHP12A; 11-14-2008 at 06:16 PM. |
Rep Power: 21 ![]() |
ooooo....i need to get the next two paychecks in. Would you take like 50% down to hold an item for another two weeks?
#3 | |
![]() ![]() ![]() rotaryshack.com |
I want / need the clutch/flywheel for the turbo 2. Does it come with the counterweight?
if i have the right counterweight ill throw it in.
Guest
Posts: n/a
I know its not on here but I figured I would ask..
drivers rear speaker cover/grill with no breaks/cracks |
Any other vert parts? Specifically the bracket/capacitors for the airbag system?
do you mean the sensors that mount to the core support? air bag control module is sold
#9 |
Not sure, I'm talking about the blue boxes attached to a bracket on the steering column under the dash...here's a pic of one:
#10 |
ill look for it. thanks for the pic!
#11 |
motor blew in the turbo II today, so i guess this is no longer on my list.
#12 | |
i have used motors too
#13 |
Rep Power: 17 ![]() |
Hey Robert if you have a TII ACV how much would that be?
#14 |
yes $25.00 shipped. a pic of the exact acv valve you want to replace would be great as there are some minor differences.
#15 |
i dont have the ACV it self bc i bought the intake mani w/o it but if a pic of the mani will help as far as which one that i have?
