Old 10-18-2008, 12:42 AM   #76
MaczPayne
Bah!
MaczPayne's Avatar
Should throw in a pinion snubber while you're at it. It's a cheap, but worthwhile upgrade.
Johnson
TA FC in the works!
Old 10-18-2008, 08:31 AM   #77
SpooledupRacing
Guest
Posts: n/a
How do I install the pinion snubber. where does it connect to and how many do I need?
Old 10-18-2008, 03:49 PM   #78
SpooledupRacing
Guest
Posts: n/a
ok so nobody local had the pinion snubber I will buy one but I don't know how it will mount and if it can be installed with everything back in the car.
Todays progress:
old OEM camber bar out
New mazda comp adjustable camber bar in:
I got the diff mounted to the subframe, the subframe back in the car, the rear sturs put in, the axles mounted.
I just need to get the bearings put in the rear hubs and on forward I can move.
Old 10-18-2008, 06:04 PM   #79
SpooledupRacing
Guest
Posts: n/a
Rear carpet is done
And I have noticed that the paint does wear off the carpet... this kinda bums me out after having probably 150.00 in paint I think I should have just taken the carpet out and swapped it for black carpet.
oh well u live and learn.
I also painted the headliner and pulled the engine harness out of the car.
Old 10-19-2008, 12:43 PM   #80
White88FC
White88FC is on a distinguished road
It seems to be coming along nicely
79 sa22c - Sold
88 fc3s TII - currently N/A - But hey it runs
White88FC is offline   Reply With Quote
Old 10-19-2008, 12:52 PM   #81
SpooledupRacing
Guest
Posts: n/a
thank you later I am going to go out and install the rear carpet and the plastic I have.
Old 10-19-2008, 02:17 PM   #82
SpooledupRacing
Guest
Posts: n/a
rear carpet is in.. but I cant put in the rear plastic till I get seat belts.
Old 10-19-2008, 07:04 PM   #83
MaczPayne
Bah!
MaczPayne's Avatar
In the bin area, there should be a dimple on the trans tunnel. Drill a hole through that, and put the snubber through from the bottom and bolt it down, with washers to adjust preload on the pinion. The snubber is an Energy suspension bumpstop you can purchase from kragen, autozone, etc.
You can do it later if you choose, but it's easier to do with the subframe out of the way.
Johnson
TA FC in the works!
Old 10-20-2008, 06:29 PM   #84
SpooledupRacing
Guest
Posts: n/a
Ok so today I took my rear spindles/hubs/bearings to have them l pressed together.. I got them back and went home and installed them on the car WOOT WOOT!!
ok so as far as I am concerned get me some wheels and I cna get the car ready to go on the ground..
I still need to buy sway bars and end links and brakes but I plan to set the car on the ground without brakes so I can roll it around during the winter..
anyways here is the pic of the rear spindle on the car !!!
Old 10-20-2008, 07:00 PM   #85
RotaryXperiment
RotaryXperiment is on a distinguished road
nice!
RotaryXperiment is offline   Reply With Quote
Old 10-20-2008, 07:07 PM   #86
SpooledupRacing
Guest
Posts: n/a
drivers side went on easy, passenger side SUCKED.. but I got them both on and I can now move on WOOT!
Old 10-22-2008, 08:30 AM   #87
SpooledupRacing
Guest
Posts: n/a
so today I ordered up my front wheel bearing washer, nut, cover, cotter pin, and dust cap so by the weekedn I will have the front hubs on and ready to put wheels under it and get it on the ground YES YES!!!
Old 10-24-2008, 06:43 PM   #88
SpooledupRacing
Guest
Posts: n/a
Ok I got the new frt hub nuts/washer/caps so I installed new inner and outter bearings, new seals, put the hubs on and put on a brand new washer, nut, cap, cotter pin and grease cap
here is a pic of one of the front hub on the car.
Old 10-24-2008, 10:44 PM   #89
RotaryXperiment
think its time to blow those leaves outside!
Old 10-25-2008, 05:15 AM   #90
SpooledupRacing
Guest
Posts: n/a
hahaha.. once I get it on some wheels I plan to roll the car out of the garage, clean the floor real good and put it back, get a tarp up and ready for the long winter.
