Old 10-15-2008, 09:50 AM   #1
88turboii
destroy, rebuild, repeat
88turboii's Avatar
tech tip: do not remove injector diffusers
on my new rebuild, i removed the injector diffusers, thinking with they were affecting the fuel flow from my bigger injectors. apparently they are very important, because it ran like crap, hesitations at cruise, AFRs all over the place, etc.
i pulled the injectors and replaced the diffusers and now she runs perfect. very smooth idle, no hesitations at all. apparently they help the fuel distribution in the air, stopping it from just hitting the opposite wall on the intake
just a heads up, incase anybody was considering removing them
Old 10-15-2008, 10:00 AM   #2
SpooledupRacing
Guest
Posts: n/a
Good info.. I knew that if I had removed them it would cause a problem with fuel atomization.. but I never wanted to test the theroy
Old 10-15-2008, 10:29 AM   #3
what i wonder is if they are still available from Mazda new
Old 10-15-2008, 10:30 AM   #4
SpooledupRacing
Guest
Posts: n/a
yes they are.
Old 10-15-2008, 10:35 AM   #5
RotaryXperiment
RotaryXperiment is on a distinguished road
i made sure to put mine in and replace with new orings per my engine builders suggestion.
RotaryXperiment is offline   Reply With Quote
Old 10-15-2008, 10:51 AM   #6
SpooledupRacing
Guest
Posts: n/a
every time I get into an engien if they wiggle loose I pull them out inspect them for cracks, replace if nessecary and always put in mew o-rings.
Old 10-15-2008, 10:53 AM   #7
for me they always seem a bit....fragile....from 20+ years of heat cycling. Would be stellar is a nice aluminum reproduction.
Old 10-15-2008, 02:30 PM   #8
need RX7
Clean S4 Nutswinger
need RX7's Avatar
I like.
Old 10-15-2008, 09:01 PM   #9
ZGN
Administrator
ZGN's Avatar
I pulled my secondary injectors ones when I installed my 1600. runs perfect!
Old 10-16-2008, 11:14 AM   #10
classicauto
crash auto?fix auto
classicauto's Avatar
Yeah I have none on my secondaries, primaries ABSOLUTELY.
Old 10-17-2008, 09:12 AM   #11
88turboii
88turboii's Avatar
sweet, i still left my secondary diffusers out. i wasnt sure if they would cause problems too. Im going to tune it in boost this weekend, so hopefully no problems. im running 1600 sec, 750 pri
Old 10-17-2008, 10:47 AM   #12
1600s are big injectors though. Not sure how effective the diffusers are at about 3 times the fuel volume
Old 10-17-2008, 12:33 PM   #13
classicauto
crash auto?fix auto
I'm running a 750/1600 combo on mine. Only using primary diffusers....seems to work just fine.
Old 10-17-2008, 01:20 PM   #14
ZGN
Administrator
ZGN's Avatar
I have heard under higher fuel pressure they could break off, and that would be bad.
