Old 09-12-2008, 08:05 AM   #1
White88FC
White88FC is on a distinguished road
Differences in clutches
Just as the title says what are the differences in a TII clutch and a NA clutch ? Are they interchangeable ? If not what would be required to make them interchange ? I've searched a few rotary specific sites now and cant seem to find info . Thanks guys
79 sa22c - Sold
88 fc3s TII - currently N/A - But hey it runs
White88FC is offline   Reply With Quote
Old 09-12-2008, 08:24 AM   #2
for starters, different diameter. i guess ill add this to the FAQ.
If you want to use a TII clutch, you would need a TII flywheel of a similiar weight balancing year. The turbo flywheel is also a single plane flywheel (easy to machine) vs. the non turbo which is a stepped plane (bitch to machine).
Old 09-12-2008, 08:25 AM   #3
be careful of sites like these.
http://www.autopartswarehouse.com/mm...kit~parts.html
notice it lists the same clutch for basically everything.
Old 09-12-2008, 08:25 AM   #4
classicauto
crash auto?fix auto
classicauto's Avatar
To run a TII clutch on an N/A you'll need a TII flywheel (with the appropriate series counterweight) and a TII trans, then either a custom drive shaft or the TII->N/A driveshaft from Racing Beat....or Mazdatrix, don't recall which one sells it. Or you'll need the rest of the TII driveline.
Vice versa for N/A clutch on a TII (why you'd do that I don't know )
The differences are the TII clutch has a larger diameter friction plate, as well as the spline count and size of the input shaft (and friction plate respecticvely) are different between the two.
Old 09-12-2008, 09:39 AM   #5
87turbo_turtle
Rotary Chic
87turbo_turtle's Avatar
87turbo_turtle is on a distinguished road
the best way I have found to see if there are diffences is look on partsamerica.com and compare what I want to do to what is stock. It beats searching fourms and visiting auto stores.
Turtle
Yes I am a girl and I will kick your butt.
Prove yourself.
87turbo_turtle is offline   Reply With Quote
Old 09-12-2008, 10:34 AM   #6
I believe the turbo clutch disc diameters are 225mm.
I think the non-turbo clutch disc diameters are 205mm.
Even if you manage to work around that, the center splines are different.
Turbo is 1" x 23.
I think the non-turbo one is 15/16" x 22.
